Looking to install Oil/Water Temp gauges and Oil Cooler, advice
Looking to get a reasonable solution for this as I have seen my temperature on my car increase by just the factory gauge when on the track. I am going to probably install the gauges under the dash cover that flips up. I wanted your recommendation on what gauges and system you recommend I install. Also for the oil cooler, is there a kit that works on our cars already made? Any advice on this would be great as well.
Thanks guys.
Thanks guys.
For an oil cooler I went with the same set up as this guy: http://public.fotki.com/ttschwing/37...oler-fabricat/
He made a thread on t h e 3 7 0 z.com
It just came in, I'm going to go install it
FWIK putting both the hoses on the bottom like that one doesn't allow to purge the air from inside the oil cooler.... will just "compress" the air based on oil pressure.
and honestly that oil cooler looks.. "weak" at least compared to my setrab 619 that is quite bigger.
FYI on the nismo we have the front yamaha damper and you probably need to go around it.
Wonder if this one will work on our cars..
http://www.gtmotorsports.com/product...9&cat=0&page=1
http://www.alteredatmosphere.com/mm5...egory_Code=G37
I know they also have a oil cooler as it's on their G37. So I would assume that would work. Stillen also has one.
The core is a pretty simple part (in function) and I haven't heard anything bad about tru-cool cores so why not try it. It was $45 and if it does ALMOST the same thing as a $2xx unit then I am happy.
The yamaha damper is the least of my worries on my car.
Couldn't you just flip it over and have the hose go up instead at the bottom? That would solve the air issue. I also would not just use tie straps to hold the hose on like he did and use clamps.
Where the oil filter mounts, I would also have the hoses going into the side of it and not down so it gives more clearance under the car.
Otherwise I like his install. Not sure how much all the parts cost in his kit though. But I am not going to spend over $400 for a oil cooler kit. (Sorry Ataru).
http://www.gtmotorsports.com/product...cat=444&page=1
are 380$ bucks.
sorry, but considering that you track the car I don't think that will be 100$ on a 7/800$ (including the two thermometers and part of the install) that will make any difference.
here we go with my install...
spa technique DG203 dual temperature gauge (set in Celsius)
<a href="http://picasaweb.google.com/lh/photo/7o5KvXsMN2wCPcxDZjgwew?feat=embedwebsite"><img src="http://lh3.ggpht.com/_txRK3mmWgA0/SlKryPLoRKI/AAAAAAAAFdw/wPKcS8s_1Hg/s800/DSC01734.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/21JbylA4Snxvu0vs-OVpkA?feat=embedwebsite"><img src="http://lh4.ggpht.com/_txRK3mmWgA0/SlKrzM6JJbI/AAAAAAAAFd0/EuidAr9yh8M/s800/DSC01735.JPG" /></a>
setrab oil cooler 619, aeroquip socketless fittings and hose and nismo power steering cooler.
<a href="http://picasaweb.google.com/lh/photo/XFOd0udTF9DJ3X9_-w-opQ?feat=embedwebsite"><img src="http://lh6.ggpht.com/_txRK3mmWgA0/SlKr0v_NBvI/AAAAAAAAFd4/wtmbSA99TME/s800/DSC01736.JPG" /></a>
<a href="http://picasaweb.google.com/lh/photo/ahhKteuO55tIoztufBUiuw?feat=embedwebsite"><img src="http://lh6.ggpht.com/_txRK3mmWgA0/SlKr2P0bTcI/AAAAAAAAFd8/RiH_0V4pZzk/s800/DSC01737.JPG" /></a>
water temperature sensor
<a href="http://picasaweb.google.com/lh/photo/htcCyIQuob0wU7wqD0mcsw?feat=embedwebsite"><img src="http://lh4.ggpht.com/_txRK3mmWgA0/SlKr33RyzvI/AAAAAAAAFeE/9P5OtSSqVcU/s800/DSC01740.JPG" /></a>
Hmmmm.....thanks for the pics. I am surprised you drilled a hole for the water temp on the side of that instead of having that adapter for one of the hoses. I will probably get that gauge. It's hard for me to tell how you have it mounted though. What is that red button?
http://deftracing.com/prosport_gauges/index.htm
Scooby guys recommend these gauges and my friend just got some. Pretty nice and really reasonable.
So how do you hook up a oil temp gauge when you have a oil cooler? Does the adapter you have allow one to be connected to it for a 1/8" NPT?
