4.08 Gears on BASE 350Z?
Old Jun 12, 2010 | 07:22 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I'm not running the Cusco anymore actually, I've switched to a Quaife now with my new final drive setup. When I ran the Cusco, I found the Motorcraft 75w140 worked best for me (@60% lock). I got it from our local autoparts store, on the recommendation of a customer/friend who is a tech for a Ferrari Challenge team.
We have the OS Fluid - IIRC it's around $45 a bottle, but I can check Monday
Old Jun 14, 2010 | 11:24 AM
c_buz's Avatar
c_buz
Question about the gears:
Does Nissan make a car that carries the 4.08 gears from factory?
Old Jun 14, 2010 | 11:30 AM
TheFarmer's Avatar
TheFarmer
05-07 2WD 4-cylinder manual transmission king cab Frontier.
Old Jun 14, 2010 | 11:38 AM
Lakeside's Avatar
Lakeside
You can pickup the gears relatively cheap if you shop around. I think I paid $450 for mine from the dealer or less. I'd have to check my reciepts. But yes they are just Frontier gears.
I also own an '08 Frontier CC and the gears when I purchased it were an option.
Zim
Old Jun 16, 2010 | 05:51 AM
FinlyZd's Avatar
FinlyZd
so you have to have vsld to get 4.08 gears. I don't even know what model my z is hahaha just bought it. I'm guessing enthusiats.
Old Jun 17, 2010 | 07:40 AM
c_buz's Avatar
c_buz
Sweet then I could prob pick them up at the junk yard for $200-$300.
Old Jun 20, 2010 | 09:06 PM
T_K's Avatar
T_K
Good luck finding a 05-07 2WD 4-cylinder manual transmission king cab Frontier.
Old Jan 13, 2011 | 11:33 AM
G3LU5's Avatar
G3LU5
I was just wondering if the OS Giken is what you carry and in your description of the OS Giken you say the difference is in the details. Then why would you put the Quaife in your own car? Is the Quaife better? I like the Quaife name but OS Giken is almost a household also. So which is better? Why?
Nevermind, I read around on some posts and have answered my own question....Thanks though
Old Jan 13, 2011 | 12:04 PM
Z1 Performance
Former Sponsor
we carry all of them
Carbonetics, ATS, Drexler, Cusco, OS Giken, Quaife, NISMO Kaaz, etc etc
This time I just decided to use something different, and I had a Quaife on the shelf that was opened and returned to us, so I used it
Old Jan 13, 2011 | 01:43 PM
blue350zed's Avatar
blue350zed
Carbonetics 1.5 way is another good one. I can't hear a thing with it using their own brand of fluid. I also have this and the 4.08 installed on my '07 base.
Old Feb 15, 2011 | 06:26 PM
zyou8er's Avatar
zyou8er
so the frontier 4.08 will they fit on a 350z lsd diff plz pm me anyone
Old Feb 15, 2011 | 09:07 PM
ace32x's Avatar
ace32x
i have a kazz 2 way with 80% lock atm and love it! it is kinda noisy though locks like a champ on the otherhand
Old Apr 30, 2011 | 03:39 AM
kingpin.andy's Avatar
kingpin.andy
Default OS Giken + 4.08
What's up guys, recently bought an OS Giken, some Redline fluid, and 4.08 fd. I haven't put it in yet, but my car is an '03 base, and I can't wait to see how it goes around corners after the swap. I'm also probably going to go with some solid bushings in the rear end just to tighten things up a bit. I'll let ya know what I think! Other mods are all the bolt ons; short intake, 5/16 iso thermal spacer, headers, HFCs, and HKS Hi-power exhaust. Right now I'm running 275/40-18s in the back and 265/40-18s in the front, so we'll see if I have any traction issues. If I do, I might be up-sizing the tires sooner than I thought. Oh, and the tires are Sumitomo HTR Z IIIs...could definitely go stickier.. Anyway, I'll let ya know my results, and my plans are to get a Vortech in about a year's time.
Old Apr 30, 2011 | 09:05 AM
AadosX's Avatar
AadosX
Enjoy it man. =)
Old May 16, 2011 | 08:57 PM
CTZ860's Avatar
CTZ860
Are you guys recommending a LSD when doing gears because the car is prone to spin more? What exactly is say a 1.5 way doing different then the stock LSD in the 350z?
Old May 17, 2011 | 08:03 AM
AadosX's Avatar
AadosX
working.
Old Jun 12, 2011 | 02:37 PM
Chrisvlad's Avatar
Chrisvlad
Quick question guys. I've read a few more threads about this and from what I've read is that everyone who has done this gear ratio swap used the 4.08 gear ratios from a 2006 Frontier for a 370z rear differential. I believe the gear rations I have came out of a 2005 Frontier. Can anyone verify if the 2005 ring and pinion will work with the 370z swap ? I have a 2004 Base Manual 350z and the rear diff from the 370z is also a manual so I know it will fit. I took it to a rear differential specialist and he said he couldnt fit the 4.08 ring and pinion into the 370z rear diff. Any info would be greatly appreciated.
Old Jun 13, 2011 | 09:58 AM
  #38
Z1 Performance
Former Sponsor
then you sorta answered your own question no?
either you don't have the right ring and pinion, or you don't have a pumpkin from a manual transmission 370Z.
Old Aug 4, 2011 | 07:50 AM
  #39
ATL_Red_G35's Avatar
ATL_Red_G35
Great topic.
I'm about to get the LSD for my base 07Z and have couple concerns.
1. Should I get the 4.08 Gear as well. I'm NA and plan to stay NA for a while. I heard it's not good when you go FI. I don't see FI in the near future as I'm still working on my driving skill, for now.
2. The car will be used on Track and Drift practices, so what kind of LSD do I need? I was leaning toward Quaife but was told to go with OS Giken as 1.5-way configuration?
Thanks,
Old Aug 5, 2011 | 12:49 AM
  #40
kramykram's Avatar
kramykram
don't go quaife if you plan to drift. i have a set of 4.083 gears for sale right now. just not listed them yet. go with os giken, nismo, kaaz, tomei.
