Underdrive Pulley for HR
Old Jun 7, 2010 | 04:02 PM
c_buz's Avatar
c_buz
Default Underdrive Pulley for HR
Can I use the DE Underdrive pulley on my HR? Has anybody done this mod?
Old Jun 7, 2010 | 04:08 PM
MDHRZ's Avatar
MDHRZ
No...
Old Jun 7, 2010 | 05:52 PM
c_buz's Avatar
c_buz
what are my options?
Old Jun 7, 2010 | 06:10 PM
Luong's Avatar
Luong
Underdrive Pulleys for the 07-08s are your options.
Old Jun 7, 2010 | 06:16 PM
biggersNISMO's Avatar
biggersNISMO
The best option is not to get one... But if you must, go with NST
Old Jun 7, 2010 | 06:19 PM
c_buz's Avatar
c_buz
Are the 370Z and 350Z pulleys the same? Stillen's website shares the same part number for both.
2007 - 2008 350Z
2009 - 2010 370Z Lightweight Standard Crank Pulley
+See Application Notes+ 400338 400338 $195.00
Old Jun 7, 2010 | 08:43 PM
biggersNISMO
2007 - 2008 350Z
http://www.nonstoptuning.com/pKitNis350.htm
get base dyno, buy it, install it, dyno it again, post conclusion
Old Jun 7, 2010 | 09:01 PM
Nexx's Avatar
Nexx
it does virtually nothing. its a waste of time money and effort.
Old Jun 7, 2010 | 09:09 PM
GAMERMODZoCOM's Avatar
GAMERMODZoCOM
Throttle response will be better but you probably won't gain anything on power. The also issue with the pulley is that you are replacing the harmonic balancer with a solid pulley. The harmonic balancer absorbs vibrations (or engine harmonics) caused by the engine at high RPM's, this will protect the bottom end.
If you aren't going to race the car or go FI, sure, the pulley is a cheap upgrade that will give you a little better throttle response (HP is debatable). If you race the car which means keeping it at high RPM's for extended lengths of time or you are going to go FI, don't do it.
Old Jun 8, 2010 | 02:47 PM
kyle22's Avatar
kyle22
Buy Test pipes or HFCs instead (Unless you allready got them). dont waste your time looking into UDP. they get you no where besides being pissed off and wanting your time and money back.
Old Jun 8, 2010 | 03:04 PM
archangel72's Avatar
archangel72
It is my understanding that with light-weight pulleys, ur not really gaining hp your freeing up hp. Meaning, just like higher gearing or weight reduction the car should feel quicker without gaing any real hp. In the accord forums we saw the same thing, it was like 1 hp difference. However, most people including myself felt a difference one the ecu adjusted. Not sure why most hr owners say they don't feel any diference.
Old Jun 8, 2010 | 04:58 PM
Luong's Avatar
Luong
Or save for 4.083 gears!
Old Jun 8, 2010 | 05:06 PM
biggersNISMO
^^^^ you sir, win!
Old Jun 8, 2010 | 05:52 PM
Lakeside's Avatar
Lakeside
I personally don't know any HR owners who are running a UD pulley. I myself bought the kit and chose not to install it. I'd be willing to sell the Stillen underdrive pulley and belt if anyone wants to make a resonable offer If not I may post it on Ebay if I get motivated to do so.
Old Jun 9, 2010 | 03:07 PM
c_buz's Avatar
c_buz
I heard Test pipes will make you loose power. I know that my brother's gixxer lost tons of torque on test pipes...but it's a bike. What will yield more power ACROSS the band HFC or test pipes?
Yeah I want this and exhaust to be my next mods.
Old Jun 9, 2010 | 04:19 PM
kyle22's Avatar
kyle22
I know from all the dynos iv seen HFCs and Test pipes (after a tune) increase HP... might be different from a bike. as far as which one has more power across the band im not to sure.
Old Jun 11, 2010 | 09:15 AM
c_buz's Avatar
c_buz
I should re phrase that. Test pipes will make you loos low end torque. Meaning 2500-4000 rpm. They benefit the power band from 4000 rpm and up.
Old Jun 20, 2010 | 01:45 PM
Phenom's Avatar
Phenom
Toasty
I maybe lost a barely noticeable amount of torque below 3k when I had test pipes installed. The mid to high end gains more than make up for any loss at the lower rpms, if any.
Old Jun 20, 2010 | 04:49 PM
C-unit's Avatar
C-unit
Personally, I would not give up the harmonic balancer for a solid pulley. if you want to upgrade, just get an ATi unit.
Old Jan 7, 2011 | 08:47 PM
theKoosh's Avatar
theKoosh
bump, so has anyone actually gotten the NST pulleys yet? the 370 guys seem to like 'em...
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
