Headers for a HR
Old Jul 12, 2010 | 03:55 PM
CaligrownZ's Avatar
CaligrownZ
Default Headers for a HR
Are are headers worth getting after full exhaust?? I've herd a lot of different things, good and bad... I herd the hr headers are pretty damn well build and with aftermarket you get either little or no gains.. Maybe after a tune or so.. Just let me know what's up.. Thanks
Old Jul 12, 2010 | 04:02 PM
CaligrownZ's Avatar
CaligrownZ
Sorry, for a repost, I'm just using my phone and it's easier this way =\
Old Jul 12, 2010 | 05:08 PM
hellsoldiers08's Avatar
hellsoldiers08
like you said, there is a lot of good and bad about the HR and De headers. Remember getting the headers is the easy part it the labor that is going to coast you the arm and leg. Also, if you do plan to get them, i would heat rape them to get the most gains out of the header.
Old Jul 12, 2010 | 09:15 PM
...and you will continue to do so.
Old Jul 13, 2010 | 08:02 AM
stock07g35s's Avatar
stock07g35s
The reason there are no real gains from headers is because they are shorty headers. They minic the factory headers and do not change the location or size of the factory cats. The factory cat placement has everything to do with emissions. If you have the nerve to run with test pipes, step up to the plate and get long tube headers.
Old Jul 13, 2010 | 08:08 AM
MDHRZ's Avatar
MDHRZ
Old Jul 13, 2010 | 10:21 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
uh, no actually, that isn't why at all
a "long tube" is not automatically better...or even longer, than a short tube with a test pipe. It's strictly a marketing term
Old Jul 13, 2010 | 11:59 AM
Nismo1534's Avatar
Nismo1534
....and the debate continues.
Anyone know if there are "long tube" headers made for the 350z HR? I see Fast Intentions makes them for the 370z.
Old Jul 13, 2010 | 12:15 PM
Z1 Performance
Former Sponsor
none that are "over the counter"
you would have to have a set custom made
Old Jul 13, 2010 | 05:23 PM
reldla1996's Avatar
reldla1996
If you want every horsepower you can get out of your NA car, then you want them. They are a lot of work to install, and the gains are small. Ceramic coating is a better solution than heat tape for a street car. I would do it again, but I can be a bit extreme in this way.....
Old Jul 13, 2010 | 05:31 PM
Lakeside's Avatar
Lakeside
^^^^ I agree if your trying to net all the obtainable HP possible out of an NA setup headers are a must have. I never wrapped mine and now regret it. I think this fall just before I take the car off the road I will go over to my friends shop and remove the headers so that I can wrap them. Lower my under hood temps and possibly net an extra Pony or two!
They are not that bad to install. I removed my headers with the cats still bolted to them.....
Zim
Old Jul 16, 2010 | 04:57 AM
blue350zed's Avatar
blue350zed
Stock HR headers aren't bad, but there is room for improvement. The head-pipes are flattened in some areas, and the collector area is not that great ( Tomei headers used for comparison ).
Attached Thumbnails Headers for a HR-rpm-pics-mid-2010-138.jpg   Headers for a HR-rpm-pics-mid-2010-609.jpg   Headers for a HR-rpm-pics-mid-2010-561.jpg   Headers for a HR-rpm-pics-mid-2010-567.jpg
Old Jul 16, 2010 | 07:09 AM
mkn's Avatar
mkn
what??? Tomei makes headers for HR ?? Since when?
Old Jul 16, 2010 | 07:20 AM
cdoxp800's Avatar
cdoxp800
There not for a HR. There for a DE. All you have to do is move one of the studs around and they fit the HR. It's real simple.
See Pic
Old Jul 16, 2010 | 07:31 AM
blue350zed's Avatar
blue350zed
See Pic
That is correct sir. The bolt holes are already on the block. You have to use the test pipe as well for it to mate up to the cat-back.
Old Jul 16, 2010 | 07:36 AM
mkn's Avatar
mkn
^ thank you
Old Jul 16, 2010 | 08:30 AM
BoomerZ33's Avatar
BoomerZ33
+1 ceramic coating works well
Old Aug 25, 2010 | 05:50 PM
wyatt51's Avatar
wyatt51
wait just to understand this more...so any header for a de will also fit a hr just by moving the studs around
and the stud hole is already on the block?
Old Aug 25, 2010 | 05:56 PM
350ztttt's Avatar
350ztttt
Got em, love em, it's faster and louder, and untuned so it'll only get even better.
Old Aug 25, 2010 | 06:00 PM
350ztttt's Avatar
350ztttt
got em with hfc's, y, pipe, and a single though, so it felt waaaay faster, cant tell what did what haha.
