How do I correct understeer?
Old Dec 25, 2004 | 02:35 PM
skirby015's Avatar
skirby015
Default How do I correct understeer?
With a 19x8 rim in the front and a 19x10 rim in the rear, I know im going to experience understeer. Can I correct it and whats the best way to do it?
Old Dec 25, 2004 | 05:44 PM
roark's Avatar
roark
You will be running quite a bit of stagger, which, as you are speculating, will add much more oversteer to the car. A much stiffer rear sway will tend to neutralize the car a bit, but won't be able to correct all of it.
You could add a front camber kit, and dial in a few degrees of neg. camber but that will really wear your tires during street driving.
Old Dec 25, 2004 | 08:49 PM
skirby015's Avatar
skirby015
I meant oversteer, sorry guys
Old Dec 26, 2004 | 11:11 AM
roark's Avatar
roark
Oops. I mistyped above. I meant you will experience more UNDERSTEER. Oversteer with that setup will not be a problem.
Sorry for the confusion.
Old Dec 27, 2004 | 04:58 PM
Q45tech's Avatar
Q45tech
Understeer is primarily created by having a too stiff front sway bar and allowing the front tires to be overloaded by cornering forces..........stronger load index front tires and a 10% weaker front sway bar will do wonders or a stiffer rear sway bar.
There are lots of ways to skin this cat [under vs over] steer.
Old Dec 28, 2004 | 02:18 PM
DBZCat's Avatar
DBZCat
get some sway bars
Old Dec 28, 2004 | 02:28 PM
tylerdurden's Avatar
tylerdurden
Coilovers and sways will help. The best results seem to be with the same size tires and wheels all around. There is a thread where someone achieved 1g on the skid pad with 9.5 BBS wheels on all 4 corners. I think they ran 255 rubber. They did sways as well I think. I'll post if I can find it.
Dr.Paulyy
Jul 29, 2019 07:45 AM
Depravity
Oct 1, 2015 04:49 PM
TrackFiddy
Sep 24, 2015 09:36 AM
