17 x 9 17mm offset and problems
Old Feb 15, 2005 | 05:19 AM
del105's Avatar
del105
15 f125
Default 17 x 9 17mm offset and problems
before I pull the trigger on a set of wheel can anyone foresee any rubbing problems with a 17x9 17mm offset with 275/40 all around?
Old Feb 15, 2005 | 08:25 AM
Pedal Pusher's Avatar
Pedal Pusher
I would think you are going to rub on the fender. I have 18x9 31mm on a G35 coupe and if the wheels were moved out 14 mm I think I would be in trouble. I had a 350Z and the wheel fitments are very similar. Also, you are changing bearing load, steering geometry and many other things with that offset. I hope someone will respond who has something closer to what you are wanting to do. If your car is lowered it will magnify these issues.
Old Feb 15, 2005 | 05:51 PM
drumma022's Avatar
drumma022
That wheel choice will be pretty far off front and rear! In comparison to an optimal fitment, the 17x9+17 wil be 10-15mm extended outward up front and will be 10-15mm retracted inward in the rear.
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it will fit, though ideally you want a mid 20's offset IMHO
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
