+22 OK Offsets?
Old Feb 16, 2005 | 12:23 PM
ZISBAK's Avatar
ZISBAK
Default +22 OK Offsets?
Hi, My friend is planning to get some 18x9/18x10 or 19x9/19x10, and he's planning to run +22 offsets on both front and rear, would that offset be ok? Or should he stay with a +32 offset front and rear? or running +22 front and +32 rear? He just not too sure if +22 would make the wheels stick out too much on the wheelwell? any info would greatly appreciated, thanks.
Old Feb 16, 2005 | 12:56 PM
King Tut's Avatar
King Tut
A +32 for the rear 10" wide wheel would probably be better as far as fender clearance. The +22 on front should be fine.
Old Feb 16, 2005 | 01:35 PM
apharmdb's Avatar
apharmdb
Should be OK with the 10 +22 rear. Problems might arise depending on whether he's lowering the car or not and what size tire he decides to run. I have a 10.5 +22 in the rear with a 285 tire and the car is lowered by about 0.7 inch. It fits perfecetly but I did have to roll the fenders a bit.
Old Feb 16, 2005 | 01:41 PM
ZISBAK's Avatar
ZISBAK
Yeah, he's planning to drop about 0.5 or 0.7 inches, and running 275/35/19 or 285/30/19 on the rear 10. But if he runs the +22 in the rear, it will definitely fill the wheelwell a lot better huh? it shouldn't stick out over the fender right? The +32 would it be too tuck in?
Old Feb 16, 2005 | 01:54 PM
apharmdb's Avatar
apharmdb
I don't think it will look too tucked in at +32. Depends on preference I guess. I wanted the wheel to sit as close toflush with the fender as possible which is why I went with an aggressive offset. But again I did have to roll my fenders to get it all to work properly.
Old Feb 16, 2005 | 03:45 PM
ZISBAK's Avatar
ZISBAK
But if he go with an +22, he should have a larger lip than the +32 right? or the offset shouldn't effect the size of the lip?
Juztin
Vendor Wanted
Sep 8, 2015 10:02 AM
