HELP!!!! I am not sure.....
Old Mar 24, 2005 | 12:11 PM
xtrememan315's Avatar
xtrememan315
Exclamation HELP!!!! I am not sure.....
I don't know much about suspension but I recently put 20s on my Z and now it looks like the to of the rim is in and the bottom of the rim is sticking out. In other words the rear wheels are "leaning" in towards the car.
What is the problem???????
PLEASE HELP!!!!
Old Mar 24, 2005 | 12:21 PM
LaidbackRacr's Avatar
LaidbackRacr
Its called camber and you can get components to correct it at z1auto, evo-r
Fairly inexpensive to fix in the rear however the front is significantly more expensive, though it is needed to make sure your tires wear properly pm me if you need direct links
Old Mar 24, 2005 | 12:32 PM
~~O8>'s Avatar
~~O8>
Kinetix makes a camber kit, camber arm and toe bolt, runs in the low $200's for just parts. That will fix it the rears, the fronts will have fewer choices, least expensive probalby in the $600 range (A arms) and it still won't fix it completely (Cusco, Kinetix).
f150intally
Feb 4, 2013 02:28 PM
andre12031948
Drag
Dec 1, 2012 12:58 AM
JasiJ
Oct 4, 2007 03:42 PM
ekim81
Jan 24, 2007 10:24 AM
Sleepy-z
Northern California
Oct 31, 2005 12:46 PM
