anyone with hks hypermax 2
Old Mar 28, 2005 | 08:15 PM
anubyss's Avatar
anubyss
Default anyone with hks hypermax 2
I just need a quick yes or no answer. I've just bought some used coilovers and from what I understand the ride height is adjusted using perches. Will I need a camber kit with these even with a minimum drop? I just need to know so I can order them and have them installed at the time if need be. Thanks.
Old Mar 28, 2005 | 08:24 PM
daytona350z's Avatar
daytona350z
i was able to pull my car barely within spec at 1/2in of a drop. i had the hks hypermax 2 as well. but u can order a camber kit just to play it safe.
Old Mar 28, 2005 | 08:42 PM
speedform's Avatar
speedform
The Z is notoriously bad for it's ease of camber adjustablility. Meaning, it has little to no adjustablilty without replacing the camber arms. (and they ain't cheap!)
I just got mine as close to stock as possible and live with it.
Old Mar 29, 2005 | 08:17 AM
JimRHIT's Avatar
JimRHIT
for front camber, you need expensive A-arm replacement
for rear, you can go to IAPDirect and get the stuff for only $90 or $200 w/ toe correction
this car's suspensio sucks to modify, but it is a dream once it is done right.
- jim
Old Mar 29, 2005 | 08:25 AM
rednezz's Avatar
rednezz
I have the HKS Hipermax II coilovers and I dropped my car about .75" in both front and rear and I was still in alignment specs but barely. If you want to drop more than that you will need to get cambers arms and toe bolts. Don't forget it takes sometime for the suspension to settle also. I orginally did a 1/2" drop and it settled around 3/4".
Old Mar 29, 2005 | 09:05 AM
anubyss's Avatar
anubyss
Thanks, I guess I'll just install them without the camber kits and see what happens. The 350evo camber kit for the front and rear is $1535 damn!
gonzalo_300zx
Dec 18, 2015 04:14 PM
Red G Coupe
Videos
Sep 8, 2015 08:36 AM
