Axis Hiros...best place to buy them ???
Old May 8, 2005 | 08:25 AM
Christopher's Avatar
Christopher
Default Axis Hiros...best place to buy them ???
I want to buy the Axis Hiros, gunmetal, (19 x 9.5, and 19 x 10.5), or (19 x 8.5 and 19 x 9.5). Wheres the best place to get a good deal on them, either wheels only or tires and wheels.
My next qusetion is, What tires should i go with on either setup ?
19 x 8.5 = 245 's ?
19 x 9.5 = 275 's ?
19 x 10.5=285 's ?
my last question is :
if i go with 19 x 9.5 's up front, can i run 275's up front , or do i go with a smaller tire ?
Old May 8, 2005 | 11:17 AM
TheInVertKING's Avatar
TheInVertKING
Yes I want to buy theses to! 19x9.5 and 19X10.5
Where is a good place?!?! i know u guys out there have these wheels because your pics are up on this site lol!
much help is appreciated
Old May 8, 2005 | 01:32 PM
Nitrouz's Avatar
Nitrouz
Back to Z
275's will DEFINITELY NOT WORK in the front. 255's are pushing it a bit already...
I would stay safe and do 245f and 275r
But there are many people running 255f and 285r but need to roll the fender a bit I think...not too sure tho. of course for these sizes you should go with 9.5f and 10.5r for the deep dish look. I believe there is someone here running 305 in the rear too...
Since you are looking at the Hiros, you might wanna check out the reverbs too. they are a bit lighter than the hiros since the hiros are cast. But the reverbs cost a little bit more tho.
Good luck.
Old May 9, 2005 | 10:44 AM
UCMyZ's Avatar
UCMyZ
I have the 9.5 - 10.5 X 19 set up. If you were my worst enemy, I wouldn't want you to go thru what I did from the place I bought them from, so I'll just leave that out.
One thing you definitely want to do your homework on is the correct size tires on the Axis Hiro's.
I was sent a rim/tire pkg w/ Falkens 245/35/19 front, and 275/30/19 rear. If you search my thread on "rims sticking out further than tires", you'll see that this is an ugly set-up (unless you are a drifter, and like it like that).
So, after about 1 month of arguing, etc w/ the place I bought these from, I asked another poster here what brand of tires he has (he has same staggered set-up), and he said Nitto's. So, thats what I got, and they fit fine - front 245/35/19, and rear 275/30/19 (they don't make 275/35/19 for nittos).
Do not use the goodyear GSD w/ sizes above because they don't fit neither. Not sure about the other brands. I could have went to a larger tire of front - 255/35/19, or rears 285/35/19, but thought I would have to roll the fenders, so I chose to stay w/ the sizes I stated in the first paragraph.
Don't listen to the Axis rep.. They are suggesting using the 245/35/19 front, and 275/30/19 rear, but they said all brands will fit, but I found out the hard way that this is not true (only nitto 555's fit in these sizes for this rim - Hiro).
So, just do your homework, and I would suggest buying from one of the larger stores, and not the little cheaper ones on the internet, or you will be sorry.
Actually, if I had to do it over again, I would get the 8.5", and 9.5" set-up and use the same sizes I stated above, but you might be able to use all brands instead of just nitto's.
Hope this helps.
Old Oct 11, 2005 | 04:56 PM
g35maxedout's Avatar
g35maxedout
Hey UCMyZ,
Do you have any pics you can post? I'm about to get the 8.5/9.5 set-up with the tires sizes you suggested, but I'll use Falken instead. I have a Dessert Platinum G35 Coupe and will get the silver wheels instead of the gunmetal. I'd luv to see yours.
G35MaxedOut
Justin100
Nov 25, 2021 06:26 AM
kyin
Oct 15, 2015 05:54 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
35reilly
Sep 28, 2015 07:42 AM
