18 x 10 +20 offset: will they fit the rear
Old May 22, 2005 | 07:00 AM
Biochem7's Avatar
Biochem7
Regular
Default 18 x 10 +20 offset: will they fit the rear
Anybody running this size rim? I just want to know if this with a 275 tire would rub (I don't plan on lowering).
thanks
Old May 22, 2005 | 09:10 AM
Nano's Avatar
Nano
they "should" fit with 275 tires, close, but they should fit. They will be very very flush with the upper part of the fender. (may require rolling).
if you lower the car or move to 285, 295 you might have problems and may require rolling fenders or some degrees of negative camber.. It's not a good setup at all if you lower the car.
I'm running 18 x 9.5 20 offset and it's very close with 275 tires
Old May 22, 2005 | 09:25 AM
drumma022's Avatar
drumma022
They will fit without a problem. The RH Pro J8 uses a 19x10 +19 in the rear and fits well with a 275/30/19.
Old May 22, 2005 | 09:33 AM
Nano's Avatar
Nano
that's also probably because 275/30-19 is a little out of spec, almost 5% error
you would want 275/35-19, way close to the stock diameter, 0.3% error
Old May 22, 2005 | 09:37 AM
drumma022's Avatar
drumma022
Yes, my mistake. 275/35/19 is the Toyo tire offered in combination with the wheel.
hulkout
Apr 28, 2017 09:00 PM
