please help me
Old Jun 8, 2005 | 04:40 PM
z scag z's Avatar
z scag z
Default please help me
I might buy a set of gewalt evo II's ( i finally found a set)
they are 19x9 fronts +31
19x10 rears +35
tires are hankook K104's: fronts 245/35/19
rears 275/30/19
I need help cause im not good with sizes.
These offsets and tire sizes are throwin me off a lil bit.
I have no clue what offsets are and jus wanna know if they are good for the 350.
And the tires are throwin me off a lil too. Ive seen similar tire sizes on 19 by 8's and 9's. I thounght 275 was for 19x9's. Can someone plese clear this up for me and also can you let me know what the difference in 35 front and 30 rear will do
thank you very much for your help
Old Jun 10, 2005 | 02:40 PM
z scag z's Avatar
z scag z
anybody?
Old Jun 10, 2005 | 03:02 PM
jran76's Avatar
jran76
Should be fine, a slighty lower offset would give you a more aggresive look (lower offset will push the wheels OUT more). IMHO, on a 9" front a +25 to +30 is a good offset and on a 10" rear maybe around the same. You are talking about 5mm's, so....
As for the tires, the fronts are great sizes, I would go with a 275/35 rear, it keeps the electronic gremilins in check better, the 275/30 throws off the tire diameter a little too much F to R. With that said, there are a lot of people that run that size and seem to be OK with it.
Old Jun 10, 2005 | 03:41 PM
JETPILOT's Avatar
JETPILOT
I have a 10.5" rear w/43mm backspace. So you're good. It will fit.
Closest to stock tire sizes are 255/35/19F, and 275/35/19R. It keeps the 20MM tire width difference to keep original oversteer, and it is less than the .72 max difference between F/R diameters.
Respect
JET
Old Jul 4, 2005 | 06:38 PM
Chico's Avatar
Chico
19x10 rears +35
rears 275/30/19
where did u find these wheels? I heard from 5Zigen that they had gone out of business.
Thanks.
Old Jul 5, 2005 | 02:44 PM
z scag z's Avatar
z scag z
ebay a while ago
