Would my rubber fit? :)
Old Jun 17, 2005 | 07:09 AM
mchong75's Avatar
mchong75
Default Would my rubber fit? :)
I just ordered my new rims yesterday but, I’m trying to figure out if the tire size I’m thinking of would rub or not.
1st scenario - The wheel size is 19x8.5 with 20mm offset front and 19x9.5 with 30mm offset rear.
I know most people go with the 245/35 – 275/35 tire setup but, I’m curious if I can use 245/40 – 275/40 without rubbing. So, would this work?
2nd scenario - No aftermarket springs yet but, if I do lower it, it might be somewhere around 1” all around. Would this rub?
Thanks for the help.
Old Jun 17, 2005 | 07:24 AM
mojo powered's Avatar
mojo powered
it could be a problem in the front, not sure.. rear would probably be ok and you can always roll the fenders..
I would think you would be ok with 20et, 245/40/19s for the front. The tire is still a 245, it's just a taller tire than it should be. And knowing that you can fit up to 275s with the proper et, I want to say you should be ok. Why do you want a taller tire size though? Is it simply because of cost or?
Old Jun 17, 2005 | 07:50 AM
mchong75's Avatar
mchong75
Highways have way too many pot holes..cracks. I want the low profile look but, with a smoother ride.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
