Cheapest way to fix bouncing problem?
Old Aug 31, 2005 | 07:20 PM
jor8888's Avatar
jor8888
Default Cheapest way to fix bouncing problem?
What is the cheapest way to fix bouncing problem? Replace rear springs with revised one and redo rear alignment? thx.
Old Aug 31, 2005 | 08:49 PM
Gsedan35's Avatar
Gsedan35
Since the revised rear springs have a heady 24% increase in rate, your already taxed oem shocks will see the problem worsen exponentially. Do not source the problem to the springs, it is the shocks job to control what the springs are doing. Replace the shocks with revised shocks or Tokico D-spec shocks. You should be able to find the shocks used in the $200 range, D-specs in the $500 range new.
Uriyo_
Sep 8, 2021 08:46 AM
