Lowering with 19's
Old Oct 29, 2005 | 08:40 PM
lemonjihwan's Avatar
lemonjihwan
Default Lowering with 19's
i just ordered 19x8.5front, 19x10.5rear rim. with 22 offset all around.
im thinking of lowering the car just about little bit to make it look perfect with the 19's.
if i just get tein springs... would it mess up my alignment + suspension? also tire problems?
what the way to lower my car? the easiest way...
thank you
Old Oct 29, 2005 | 08:47 PM
CervanteZ's Avatar
CervanteZ
Done it, work perfectly. I put the S-Tech Tein Springs, couldn't ask for a better drop. Didn't need any camber adjustment and such. These springs range from .70(Front).60(Rear). Had them installed proffesionally. All together, springs and labor+alignment should be about 400-500 Beans. I recommend doing it proffesionally. Found a good set on ebay.
No suspension problems, and no feathering, the alignment was done by Firestone, didn't do a good job on it though. My steering wheel is a little crooked to the left. Common prob. easy fix.
Good luck. If you need pics to see what it looks like, PM or IM me.
Peace.
Old Oct 31, 2005 | 11:44 AM
king james's Avatar
king james
Or, you can go Eibach springs. Pro-kit lowers it 1'' front and back.
Old Oct 31, 2005 | 03:43 PM
lemonjihwan
do i have to worry about my stock shocks?
May 30, 2017 03:28 PM
James1990
Dec 16, 2015 08:57 PM
