Volk SF-Winning 19 x 9.5/10.5 Pics (56K warning)
What brand tires are you running? Also, what kind of drop are you going to go with? If you go with a subtle drop (i.e. Hotchkis, Tein, RS-R springs), let me know! If it's not too much trouble, I just may go ahead and get another set or rears with a +17 offset!
The tires on the back are Bridgestone S03 and the front is Fuzion. I bought these wheels from someone local, thats why the tires are mismatched.
I had ordered another set of wheels that never came in after close to 3 months, and it just happened that I found these Volks.
I always like the Winnings from the day I saw them on John350z's Z way way back...
https://my350z.com/forum/showthread....ght=sf-winning
but I knew then that the wait and the $$$ was too much. I guess I got what I wished for 3 yrs later.
You guys are crazy buying wheels that don't fit properly and then trying to correct the problem with negative camber.
How much negative camber are you thinking of dialing in here to get these to tuck under the fender?
I know... to each his own, but I just don't get it.
Am I the only one that thinks this is rediculous? Or just the only one stupid enough to open their mouth. I think I'm about to get my *** flamed. Flame Away
Just watch you don't sideswipe any parked cars with the tire sticking out in the breeze.
Respect
JET
Respect
JET
Camber is not a "look"... It's a requirment for the car to handle properly. You just don't decide to adjust camber to fit the wheels on the car. Camber is not "fasionable". The suspension settings have to work with the car, NOT AGAINST IT.
This is soooo ricey!!!!
With these offsets camber is a requirment to fit the wheel on the car properly. Why not buy a wheel that fits properly, and then camber is an option instead of a requirment.
Respcet
JET
Respcet
JET
Respcet
JET
Respcet
JET
Just lowering it will produce some negative camber. Then with some slight fender modification, he's set
Respect
JET
Respect
JET
Right now my camber is at -1.1. I think lowered to about 3/4-1" and about -2-2.5 or so camber with the fenders rolled would work. Probably the camber wouldnt go any further if the S03's sidewall wasnt so straight.
You going to do this soon? I would like to see if it works out.
Respect
JET
Respect
JET
Respect
JET
Respect
JET
Originally Posted by Selski12
cool BhashaZ!! Know what kind of springs these guys are using? Trying to research which to get.
Silverstone: Coilovers
Daytona Blue: Tanabe springs (don't know which ones...)
Super Black: Coilovers?
Redline: cut springs (?) I think...
It looks like I have plenty of room though with these 275/30's...
