Work Wheels Thread
Old Jan 11, 2012 | 06:34 PM
  #861
Waiz's Avatar
Waiz
Threads merged..
Originally Posted by tkuntz
are these the wheels your looking for?
Attachment 330499
Those wheels are Volk RE-30's
Old Jan 11, 2012 | 07:51 PM
  #862
tkuntz's Avatar
tkuntz
Originally Posted by Waizzz
Threads merged..
oops my bad, looked similar kinda.
  #863
Javi04's Avatar
Javi04
Threads merged..
Looks more like Volk G10
Old Jan 11, 2012 | 07:57 PM
  #864
omsin523's Avatar
omsin523
or le28n?
Old Jan 11, 2012 | 08:07 PM
  #865
TwoFastFurYa's Avatar
TwoFastFurYa
Why do all the threads show up in reverse order? For instance, I clicked on this one, and I had to click on page 2 in order to see the 1st post about what the thread is about LOL...The first post on page 1 is the most recent??!! Meaning my post will be the most recent? WTH??
Old Jan 11, 2012 | 09:57 PM
  #866
Waiz's Avatar
Waiz
^Sounds like a glitch in the matrix.
Actually, they are Formula Silver CE-28N's.
I know the owner but it's been awhile since I've seen that Z.
Old Jan 12, 2012 | 06:11 AM
  #867
skoke70's Avatar
skoke70
You have to change the settings in the user cp (top left)
Old Jan 27, 2012 | 10:14 AM
  #868
RavSpec's Avatar
RavSpec
Vendor - Former Vendor
Default WORK Shadow Black Color Scheme (with Purple Base)
WORK Shadow Black Color Scheme (MDB Black Center with Purple Base + Glossy Black Anodized Barrel)
http://www.flickr.com/photos/jdmwheel/6772062289/http://www.flickr.com/photos/jdmwheel/6772062289/ by http://www.flickr.com/people/jdmwheel/, on Flickr
http://www.flickr.com/photos/jdmwheel/6772062749/http://www.flickr.com/photos/jdmwheel/6772062749/ by http://www.flickr.com/people/jdmwheel/, on Flickr
http://www.flickr.com/photos/jdmwheel/6772063389/http://www.flickr.com/photos/jdmwheel/6772063389/ by http://www.flickr.com/people/jdmwheel/, on Flickr
http://www.flickr.com/photos/jdmwheel/6772062929/http://www.flickr.com/photos/jdmwheel/6772062929/ by http://www.flickr.com/people/jdmwheel/, on Flickr
Old Jan 27, 2012 | 10:18 AM
  #869
Stance350zee's Avatar
Stance350zee
how much would these run ?
Old Jan 27, 2012 | 02:08 PM
  #870
redman333's Avatar
redman333
wow that looks good
Old Jan 27, 2012 | 02:42 PM
  #871
BoomerZ33's Avatar
BoomerZ33
those are so sexy
Old Jan 27, 2012 | 03:33 PM
  #872
RavSpec's Avatar
RavSpec
depending on the which WORK Wheels , $3500 ~ $4200 range.
The barrel are anodized black.
Old Jan 28, 2012 | 10:02 AM
  #873
JCITY's Avatar
JCITY
Would look great on a brickyard.
Old Feb 3, 2012 | 05:55 AM
  #874
SilverZ350's Avatar
SilverZ350
Default Work REZAX Wheels
will these fit my 08 350z? do you think they would be good fitment wise or need spacers?
Wheel specs:
Style: multi 3 piece
Lug pattern: 5x114.3
(2) 18x8.5f +45 offset
(2) 18x9.5r +45 offset
<a href="http://smg.photobucket.com/albums/v464/Wraith101/?action=view&amp;current=4h7hoz.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v464/Wraith101/4h7hoz.jpg" border="0" alt="Photobucket"></a>
Old Feb 3, 2012 | 06:03 AM
  #875
lgear080's Avatar
lgear080
/thread
Old Feb 3, 2012 | 06:06 AM
  #876
AroundMyHorn's Avatar
AroundMyHorn
Originally Posted by lgear080
/thread
In other words, don't even think about it OP.
Old Feb 3, 2012 | 06:19 AM
  #877
SilverZ350's Avatar
SilverZ350
good clear answer, not much of a fitment guy so figured a quick answer would work
Old Feb 3, 2012 | 07:25 AM
  #878
SA Z-boi's Avatar
SA Z-boi
you can easily rebarrel these to get a better offset
Old Feb 3, 2012 | 07:43 AM
  #879
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
Those are more like a 240SX or even an aggro S2k fitment. I'd buy them IF you can afford to have them rebarrelled. If WORK can't help you, I know 2 other companies that can.
Old Feb 3, 2012 | 09:12 AM
  #880
Waiz's Avatar
Waiz
Those offsets are not ideal for a 350z, a G35 sedan would be better suited.
Reminder, this info can be found in our "Top 100 Questions Thread"
https://my350z.com/forum/2003-2009-n...questions.html
https://my350z.com/forum/2487452-post8.html
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.<!-- google_ad_section_end -->
<!-- / message --><!-- edit note -->
