My wheels have ARRIVED!
Old Nov 21, 2005 | 01:03 PM
  #61
drumma022's Avatar
drumma022
The middle pic is actually with camber adjusted by eye. I had them take out another .3 degrees since then. She rubs every now and then, but nothing serious.
Old Nov 21, 2005 | 01:31 PM
  #62
350Z_Italy's Avatar
350Z_Italy
Originally Posted by drumma022
Zexy -- Since you are not posting pictures, I have decided to jack this thread and post some interesting wheel fitments on stock fenders on the Z!
Here is side-by-side pic of 03Z33 (x9+5, x10-7) next to my car (x9.5+11, x10.5+11):
Ehi where have you find this pics!!i love the last setup!!!
Old Nov 21, 2005 | 02:26 PM
  #63
03Z33's Avatar
03Z33
Drumma, Our front wheels actually sit at exactly the same place in relation to the front fender... just that my rear wheel sticks out an additional 12mm
That means you can place a 10mm spacer on your rear wheel and it will still fit fine! DO IT!!! what size tires are you running? Your car looks like you have some pretty aggressive camber I haven't had to change camber at all on mine, just running a small tire and cut/rolled the fenders. I can easily fit a 275 tire with no other changes.
Old Nov 21, 2005 | 03:40 PM
  #64
Zexy's Avatar
Zexy
You guys are gonna kill me.
The wheels will get here next monday to tuesday. Ground shipping from Cali to Florida sucks ****.
Old Nov 21, 2005 | 03:49 PM
  #65
Rickdogg's Avatar
Rickdogg
Out of hiatus
BAN!!!!!!!!!!
Old Nov 21, 2005 | 03:56 PM
  #66
Zexy's Avatar
Zexy
lol
  #67
03Z33's Avatar
03Z33
It's all good, the more you wait the better it is when you get them
Old Nov 21, 2005 | 04:16 PM
  #68
Rickdogg's Avatar
Rickdogg
Out of hiatus
That is what virgins say JP man.
Old Nov 21, 2005 | 04:44 PM
  #69
drumma022's Avatar
drumma022
03Z33: -2(F) -3(R) degrees camber + stock fenders (not even rolled cause i'm lazy) + 235/30/19(F) 265/30/19(R) = My Setup - Minor rubbing.
I just may get a set of 10mm spacers and see hot it looks. Question - do to stock lugs have enough thread to fit a 10mm spacer on?
Old Nov 21, 2005 | 05:38 PM
  #70
03Z33's Avatar
03Z33
you should get the Nismo 50mm studs if you wan to run 10mm spacer in rear. 6 mm is max with stock studs. 60mm studs will allow for up to 15mm spacer.
Old Nov 21, 2005 | 08:57 PM
  #71
dank311's Avatar
dank311
For those who have the S1's, what are you using for lug nuts. Are you using stock, or aftermarket lug nuts? I was thinking of going with aftermarket, but didn't know which will fit best, and which is a good brand. Is muteki any good? Also, would the short or extended lugs fit best? Can stock lugs even fit in this wheel?
Old Nov 21, 2005 | 09:35 PM
  #72
03Z33's Avatar
03Z33
stock lugs are probably too wide and may not have the right taper... I run the Nismo Longs and the Kyokugen (spelling?) open ended ones which both use the same adapter tool (also usefull for theft prevention)
Old Nov 22, 2005 | 05:33 AM
  #73
drumma022's Avatar
drumma022
Careful with the Kyokugens, I have had a co-employee break his tool a total of 5 times because the nut rusted onto the lug .. just make sure you use some good anti-sieze.
Old Nov 22, 2005 | 06:40 AM
  #74
03Z33's Avatar
03Z33
I know they're cheap and will strip if over torqued or used for too long... I've usually replace my wheel studs and lug nuts 1-2 times a year since the wheels are on and off so much.
Old Nov 22, 2005 | 10:17 AM
  #75
350Z_Italy's Avatar
350Z_Italy
Really good!!
Old Nov 22, 2005 | 10:35 AM
  #76
drumma022's Avatar
drumma022
I am just using 18mm plain lug nuts, and 2 diff nissan wheel locks all around.
03Z33 - whats your name? are you on any other boards like ziptied?
Old Nov 22, 2005 | 01:36 PM
  #77
cwest350's Avatar
cwest350
Originally Posted by Rickdogg
BAN!!!!!!!!!!
+1 jp
Old Nov 22, 2005 | 04:13 PM
  #78
bmxox's Avatar
bmxox
Those aren't the sizes on my car just what I think would look great on a stock Z!
I never said they were on your car, just asking if you knew the tire size since you posted the pic and knew the widths and offsets, someone else commented them on being your wheels and the tires being too skinny.
Any one else know what size tires are on those wheels pictured on page 2? (18x11.5 and 18x10)
Old Nov 22, 2005 | 04:32 PM
  #79
drumma022's Avatar
drumma022
Which post # ???
Old Nov 23, 2005 | 05:18 AM
  #80
Zexy's Avatar
Zexy
I've had dreams about my wheels for the last 2 days
Originally Posted by concuthatbu
These are ugly and heavy wheels....I like Volks Racing Te37 better...more name brand and better style. This is just my personal opinion. Dont want to offend anyone
Just to notify your dumb azz.
These wheels must be extremely light for what they are.
Total shipping weight=80 lbs total. About 20 a wheel!
