275s or 285s with 18x10?
Old Nov 22, 2005 | 11:33 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
here is my car on 265/35/18 / 295/35/18
Old Nov 22, 2005 | 11:43 AM
NA&CH's Avatar
NA&CH
Hey Thanks Jason. Car looks good. nice paint
Old Nov 22, 2005 | 12:44 PM
ZON's Avatar
ZON
But you did something with your fenders, right? Stretched them a little?
Old Nov 22, 2005 | 12:53 PM
002-M-P's Avatar
002-M-P
Jason...what width and offset are those wheel?
Old Nov 22, 2005 | 03:40 PM
Jason@Performance
Performance Nissan
I pulled them because im going to do 18x10 / 18x12 next
I have had them on with stock fenders before...
here is a roadster with the same exact set up as me stock suspension stock fenders...
Here is a pic of the inner fender clearance on the rear... inside)
my car slammed...
Old Nov 22, 2005 | 03:42 PM
Jason@Performance
Performance Nissan
18x9.5 +27 w 265/35/18
18x10.5 +30 w 295/35/18
shorter then stock diameter... but keeps the same staggard as far as front shorter / rear taller like stock so it does not effect VDC... but does effect speedo...
Old Nov 23, 2005 | 01:01 AM
Axewielder's Avatar
Axewielder
Looks Killer
Old Nov 23, 2005 | 04:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by palepony
alberto
thanks for real world experience. i was hoping you would chime in as you own 255/285
but i have to ask: do you not think your z is slower with that much tire? more planted, yes i agree, but faster? i will stand corrected by you as you have very fast NA 1/4mile times. sorry i haven't been following the drag forum, did you achieve those times with 255/285 or with a smaller size?
that being said as well, you are pushing the limits of traction with agressive launches at the drag strip. chimmike states he is only a street driver. i don't think he'll light up a set of 275's
again, i qualified all my comments as my opinion . others may vary
pp
I didnt run those times with the 19's but I can tell you something. From a stop, my 19's will outlaunch my stock 18" rims anyday. From a roll the car feels very slightly heavier. I had a track, so I went from 18.X lb rims to 20 and 21lb rims but went up a few pounds in tire weight. Now question Im slightly slower on the 19's but not enough to make a huge difference, and like I said the feeling the new tires give the car is amazing, so much traction at the limit taking corners, its much more confidence inspiring.
Old Nov 23, 2005 | 11:13 AM
palepony's Avatar
palepony
thanks alberto
i think, my opinion again , that many would look to you as the man to ask about the limits of straight line rear traction on a N/A Z
"my 19's will outlaunch my stock 18" rims anyday" - what tires did you have on your stock track wheels?
"the car feels very slightly heavier" - i agree, that's why i asked, and i went to 275
"its much more confidence inspiring" - YES
pp
Old Nov 23, 2005 | 12:23 PM
zman2's Avatar
zman2
Jason:
TPS work with those wheels?
Old Nov 23, 2005 | 04:51 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thumbs up
thanks alberto
pp
Thanks for the kind words...On stock rims Ive had the stock RE040's, S03's, Goodyear F1's, Yokohama ES100's, and Falken ZX somethings. The BFG KDWII's on my 19's grip better off the line. I think its mainly due to the massive width over stock. Ive pulled 2.0 60ft's on every set of tires Ive had on my stock rims. I havent run the 19's down the track yet, unfortunately I dont think I will run the 19's NA, Ill be installing my Turbonetics kit shortly after X-mas Be sure to post pics of your set-up when you get your tires
Old Jan 29, 2006 | 02:02 PM
Anomaly460's Avatar
Anomaly460
Back from the dead.....would 18x9 +21 18x10 +23 with 255/35/18 and 285/35/15 work similar to this setup? Meaning everything should be ok but the speedo will be a little off? Or do you think 245/35 and 275/35 would be better for my setup? btw most of my driving is spirited street...dont plan on tracking my car.
Old Jan 29, 2006 | 02:06 PM
Anomaly460's Avatar
Anomaly460
just checked and the tires i was looking at arent available in 285/35...so next question is would 255f275r be enough stagger?
Old Jan 30, 2006 | 08:18 AM
arizzee's Avatar
arizzee
yes but don't run the 35 aspect ratio tires - they are too short. I've been running 255/40/18 fr & 275/40/18 just fine. This combination on 18" wheel is very close to stock diameters, speedo will not be off by much (0.2%) . If you run the 35 tire on a 18" wheel, your speedo will be off for sure ( how much - 4.2%).
Old Jan 30, 2006 | 08:39 AM
SpeedRcr's Avatar
SpeedRcr
295*35 is what i have on my rear with a 10 in wheel
Old Jan 30, 2006 | 09:52 AM
Anomaly460's Avatar
Anomaly460
do you have 18x9/10??? If so do your tires looked stretched in those sizes?? Any pics? Speedrcr any pics? thanks for the help guys
Old Jan 30, 2006 | 10:19 AM
arizzee's Avatar
arizzee
I'm running 8.5"f 9.5"r. 275/40 on a 10" should be fine, the width range is 9" -11".
Old Jan 30, 2006 | 10:25 AM
  #38
gooleung's Avatar
gooleung
I have been running 265/35/18 F and 285/35/18 R,
Rims are 18x9 22+ F and 18x10 22+ R
Tires are Falken FK451
Tires dont look stretch at all. But I if can choose again, I would prefer 255 in the front. So that the front wheel will looks better.
It will work with VDC and speedo will be off.
Will clear fender
By the way, I am selling this setup
Matt
Old Jan 30, 2006 | 01:45 PM
  #39
Anomaly460's Avatar
Anomaly460
Will clear fender
Matt
Thanks for the pics gooleung...im gonna try 255/35/18 and 285/35/18. You said your vdc/tcs works fine correct?? What makes you wish you went with 255 instead of 265??
Old Jan 30, 2006 | 06:20 PM
  #40
gooleung's Avatar
gooleung
You welcome Yup, My VDC just work fine. 255 instead of 265 will make your front wheels a bit smaller and more staggered look. You might want to check out this website. I think it is very useful.
http://www.miata.net/garage/tirecalc.html
