18x11 GT-C = WOAH! So Long 19"
Old Dec 19, 2005 | 05:56 PM
  #41
ZRAYGO's Avatar
ZRAYGO
can anyone answer the ? as to why the 18x11 and no tthe 19x11 will fit in the rear of the car? or does mackin even make a 19x11 in the GTC? i fso ho wmuch do they cost and does anyone have a pic?
Old Dec 19, 2005 | 07:56 PM
  #42
gooleung's Avatar
gooleung
Originally Posted by kosmic
Jason, please give us the details in offsets, tire size, lowering, etc for how you're going to make 18x10 fit up front. Thanks
OK..Maybe I can answer the question here because I have a set of 18x9 and 18x10 +22 all around which I am selling now.
Links to my Rims for sell
It all depends on how low the car is, offset of the rims,size of the rims,tire size and camber....
From my experience, 18x10 +22 with 285/35/18 My car was slam 2" which means the rear fender is covering my tires. I still have 3-5mm gap between rear fender and side wall of tire. On the front, 18x9 +22 with 265/35/18 I still have 10-15mm space.
With this size and offset, I can easliy go for 295 at the rear without any rubbing problem. Also for the front. it will fit 18x10 as long as the offset dont go beyond +22.
For 18x11 and the rear, it all depends on the offset. If the offset on the rims is +30 then of cuz it will fit. if the rims offset is +22 then I am guarantee that wil not fit no matter what size of tires is unless fender is rolled.
The above suggestion is without any camber kit.
Thanks
Matt
Old Dec 19, 2005 | 08:12 PM
  #43
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
So...I guess the offsets and tire sizes are a secret then? I just didn't know it was possible to fit that much wheel up front, especially with a lowered suspension, unless the fenders are rolled.
I think you'll get just as many sales if you reveal your secret, but if you don't think so, that's your call.
You can fit a 10 up front no problem with the correct wheel offset and tire size...
they only make up to 19x10.5 and only make half sizes for the wider 19's...
Old Dec 20, 2005 | 10:55 AM
  #44
kosmic's Avatar
kosmic
My question was: "What are the correct wheel offset and tire size to use?" Especially if lowered, say with a nismo suspension.
Old Dec 20, 2005 | 11:09 AM
  #45
jvega's Avatar
jvega
I have 19x 10.5 in rear GT-C's with T1-S 275-35. It has a stretched look, but no rubbing. No rolled fenders. I think 295 would likely rub though.
Old Dec 20, 2005 | 01:02 PM
  #46
03Black350Z's Avatar
03Black350Z
nice lip
sales@czp
Sep 23, 2019 03:30 PM
_bit
Oct 2, 2015 07:49 AM
Depravity
Oct 1, 2015 04:49 PM
