255/45 on the stock 18" (non-track) rear rim?
Old Dec 13, 2005 | 06:55 AM
Jun's Avatar
Jun
Default 255/45 on the stock 18" (non-track) rear rim?
Any problems with this setup?
I am currently running 245/40 all around, and want to go a little wider with the rear tires. Will I have any problems using 255/45 (since stock profile is 45 anyway).
I have a Base model so no problems with TCS/etc.
Thanks in advance.
Jun
Old Dec 14, 2005 | 04:21 AM
Alpha's Avatar
Alpha
I have 255/45/18 KDW2 on all 4 touring rims. No problems at all.
Old Dec 14, 2005 | 06:24 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
You have 245/45 on the fronts as well. I thought you couldn't fit 245 on the fronts. Just ordered 225/45 & 245/45 KDW2 also.
Old Dec 14, 2005 | 07:56 AM
Acree's Avatar
Acree
do you have any pictures?! i am wanting to run the exact same setup but with 255/35/18. also, where did you purchase from and how much? (if you don't mind me asking)
Old Dec 14, 2005 | 08:05 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Sorry Jun for jacking your thread. lol Acree I just bought my KDW tires from Discount Tire Direct: https://my350z.com/forum/wheels-and-tires/158456-ordered-bfg-kdw-nt.html
Old Dec 14, 2005 | 08:25 AM
Alpha's Avatar
Alpha
Sure you can, touring rims are 8'' wide, which fits a 255/45/18 KWD2. No pics though.
Old Dec 14, 2005 | 08:48 AM
Acree's Avatar
Acree
awesome! robert post up pics when you get em mounted. i dont know what middle number i should go with. what do you guys think? i know i want 255/XX/18 all the way around but what would look and perform the best? I am dropped 1 inch in the front and 1.2 inches in the rear if that helps any.
Old Dec 14, 2005 | 09:01 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I say stick with the stock sizes, unless you get a larger wheel. Changing the size of tire alters your speedo and odometer.
Old Dec 14, 2005 | 09:57 AM
Jun's Avatar
Jun
Originally Posted by Robert_K
Sorry Jun for jacking your thread. lol Acree I just bought my KDW tires from Discount Tire Direct: https://my350z.com/forum/showthread.php?t=158456
no problem dude.
I just bought the KDW NT for the rear, 255/40 18
i'll post pics when i have them mounted!
Old Dec 14, 2005 | 09:58 AM
Jun's Avatar
Jun
I would say go 255/40 in the rear, 245/40 up front. That way you have a somewhat staggered setup.
the 245 up front should help you with understeer.
Stock size is 225F/245R. IMO, i think 225 is too small for up front (which is why i have 245/40 up front now).
Old Dec 14, 2005 | 11:00 AM
Chad68's Avatar
Chad68
Um you sure you meant to say a 35 series and not a 40 series or even a 45?
Don't know how to say this but a 255/35/18 will look waaayyyyy not right.
A 255/40/18 would be waaaay better. Your wheel wells will look HUGE and your wheels tiny and your sidewalls will look way too thin as well, not to mention the speedo will be off quite a bit.
Old Dec 14, 2005 | 12:56 PM
Acree's Avatar
Acree
No, I definately was not sure. That's one reason I posted in this thread is to get recommendations. Thanks for the heads up and I will more than likely order 4 255/40/18.
Old Dec 14, 2005 | 04:57 PM
1nate7's Avatar
1nate7
Originally Posted by Jun
no problem dude.
I was just going to recommend that size. I think you made the right choice. I ran the 245/40, 255/45 combo on my G35 and to me it made the rear look higher because of the increased stagger.
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
