hubcentric rings for Axis Hiro ??
Old Jan 10, 2006 | 10:30 AM
MRfire's Avatar
MRfire
Default hubcentric rings for Axis Hiro ??
Does anyone know what size I need? I know the hub is 66.1, but what about the other?? Thanks in advance!!
Old Jan 11, 2006 | 01:23 AM
Z33GRIP's Avatar
Z33GRIP
You should call Axis and ask them what the center bore size is on the wheel you have. They should have the center bore size. Most standard wheels that are massed produced to fit different vehicles (wheels not built to vehicle spec) have a center bore of 73mm. Again, because we don't know if your specific wheel was built for 350Z's (and most likely not), you should make sure what the exact center bore size is. I know this doesn't answer your question but it'll help you get it.
Old Jan 11, 2006 | 08:21 PM
Triple8Sol's Avatar
Triple8Sol
Or just call/go to a tire shop like Discount, etc... They can do the legwork for you, and order it in for you as well.
lolwatbro
Oct 9, 2021 04:58 AM
35reilly
Sep 28, 2015 07:42 AM
abarclay
Wheels Tires
Sep 21, 2015 04:51 AM
