Need tire advice quick
Old Jan 19, 2006 | 08:41 AM
oaktown2000's Avatar
oaktown2000
Default Need tire advice quick
Riding around on a doughnut right now and need to replace the front tire quickly. The only shop that has anything in stock available today has Pirellis. However...he says they don't have a 225/50R17 for the stock 17" rims. Will a 235/50R17 be OK???? Would there be any problems or potential problems with getting this tire size?? I need to replace it ASAP. Thanks for any info
Old Jan 19, 2006 | 08:45 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
225 to 235 is not much of different.
Old Jan 19, 2006 | 08:47 AM
oaktown2000
So I shouldn't have any problems with putting a 235/50 R17 on the front then?
Old Jan 19, 2006 | 08:51 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
no
Old Jan 19, 2006 | 09:03 AM
mgl's Avatar
mgl
are you gonna be replace 1 front or both front tires? if you are changing just one, then you need it to match the other 225.
also, i haven't looked at the oem 17s in awhile, but whats the size of the rear tire? isn't it a 235/50/17? cuz if you are gonna run all 4 tires that are the same size, you might run into some "slip" light problems (depending on what model your z is)
Old Jan 19, 2006 | 09:13 AM
oaktown2000
I was planning on getting 2 new tires for the front (possibly even just get all 4 at the same time). And my Z is just the base model...so no VDC. So I'm good to go with 235/50 all the way around right.
Old Jan 19, 2006 | 09:16 AM
mgl's Avatar
mgl
yup! go for it
you'll even have the luxury of rotating your tires
oaktown2000
K...thanks a lot for the info...I appreciate it
Old Jan 19, 2006 | 03:06 PM
blap0220's Avatar
blap0220
Would I be able to go from 245 on my stock 06 rear wheels to 265? Would I need to worry about problems if I did this?
Old Jan 19, 2006 | 09:33 PM
Click here for more than you ever wanted to know about wheels and tires for the 350Z
http://www.350zmotoring.com/modules....ex&name=Wheels
Old Jan 24, 2006 | 08:19 AM
Did you use the chart above for the proper tires sizes? What sizes did you select?
Old Jan 24, 2006 | 08:22 AM
oaktown2000
I got 4 tires...all 235/50R17s....and the ride is smooth and I haven't had any issues at all.
Old Jan 24, 2006 | 09:48 AM
Thumbs up
Thanks for replying.
lapham3
Oct 7, 2022 03:15 PM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
