Volk TE37 tire question
Old Feb 9, 2006 | 02:30 PM
joeun's Avatar
joeun
Default Volk TE37 tire question
You probably have read this question too many times, but I searched and couldn't quite find an answer for my particular question. Maybe I didn't look hard enough. I purchased recently Volk TE37's 19" x9.5 front and 19"x10.5 in rear. I'm thinking dropping car .8" and needing to see what tire size is optimal for front and rear. I know most go 245/35/19 front and 275/35/19 rear. Is this best size to go or could you go 285 in the back without any problems? I also was thinking of going with BF Goodrich KDW's. Any other tire brands I should check out? Thanks!!
Old Feb 9, 2006 | 02:53 PM
350Zteve's Avatar
350Zteve
How wide you go will depend on your offsets. In the rear, if its +22 offset, your going to rub with a 285 and maybe even a little with a 275. You can roll the fenders though. If you get a +30 offset in the rear, you can run a 295.
BFG's are my favorites, so those would be a good choice
Old Feb 9, 2006 | 04:03 PM
joeun's Avatar
joeun
thanks...I forgot the offsets didn't I...they are +22 front and rear.
Old Feb 9, 2006 | 06:37 PM
JPsZ's Avatar
JPsZ
I believe if they're +22mm offset and you lower your car running a 285 in the rear you will need to roll your fender or it'll rub slightly, unless you go with major negative camber to push the top of the wheel in.
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Stevo Z
Oct 3, 2015 09:14 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
