torque specs?
Old Feb 20, 2006 | 01:52 PM
igetgreens's Avatar
igetgreens
Default torque specs?
Had to remove the front left wheel to instal cold air intake...i couldn;t find the torque specs anywhere so i just set it to 150. could you please tell me if i am alright?
thanks
Old Feb 20, 2006 | 01:57 PM
Chris@DTD's Avatar
Chris@DTD
No. You need to loosen that ASAP.
Torque to 90 lb-ft
Old Feb 20, 2006 | 02:02 PM
Mike Wazowski's Avatar
Mike Wazowski
hey is 90 is good, wouldnt 150 be 66.7% better?
j/k
Old Feb 20, 2006 | 02:14 PM
ANXIOUZ's Avatar
ANXIOUZ
What kind of intake did you install that required you to remove the wheel?
Old Feb 20, 2006 | 09:52 PM
Volk350Z's Avatar
Volk350Z
Master
I do mine at 80 lb ft.. but after you drive it around the block re torque it again..
Old Feb 20, 2006 | 09:57 PM
igetgreens's Avatar
igetgreens
nismo v2 cold air
Old Feb 20, 2006 | 10:01 PM
igetgreens's Avatar
igetgreens
so is torquing to 150 bad?
Old Feb 20, 2006 | 10:05 PM
Volk350Z's Avatar
Volk350Z
Master
ahh yeah .. if you over tighten it you can messup your stud...
Old Feb 21, 2006 | 06:50 AM
noodleman's Avatar
noodleman
call me a noob, but how do you measure how much torque you applied to the lugs?
Old Feb 21, 2006 | 06:58 AM
Mike Wazowski
A torque wrench.
Old Feb 21, 2006 | 07:22 AM
150 foot pounds will do it. The wheel may be cracked, but it sure will not fall off.
Old Feb 21, 2006 | 07:24 AM
Tighten until your elbow aches - they back off one quarter turn.
Old Feb 21, 2006 | 07:53 AM
Kolia's Avatar
Kolia
thanks
That’s a good way to have a lug snap from fatigue.
Plus, good luck loosing them with the tiny bar should you get a flat tire. It’ll probably be dark and raining when you need the use it too !
Better yet! Torque only one bolt to 150 and the rest to 80 and get a foot massage when you brake (from the twisted rotor…)
Old Feb 21, 2006 | 08:03 AM
MyNismoRoadster's Avatar
MyNismoRoadster
I torque mine down to 84lbs, no problems so far. Its always best to use a torque wrench for wheels.
Old Feb 21, 2006 | 08:28 AM
drifter23's Avatar
drifter23
85lbs is what the manual says.
Old Feb 21, 2006 | 05:31 PM
xephiron's Avatar
xephiron
lol, or you can do like most and set the TQ wrench to 100 foot/pounds and make it click 4 times per wheel
Old Feb 21, 2006 | 06:37 PM
igetgreens's Avatar
igetgreens
so am i basically screwed since i torqued it to 150? i looked all over the manual but couldn't find it
Old Feb 21, 2006 | 09:55 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
not screwed... Just remove your lug nuts, check the wheel hub bolts to make sure they havent stretched or show any signs of cracks...
put back on torque between 74-80 ft-lbs (foot pounds) depending on your lug nuts...
Depravity
Oct 1, 2015 04:49 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
