Need help with tires fast!
Old Mar 31, 2006 | 10:34 AM
infidsg35's Avatar
infidsg35
Default Need help with tires fast!
Ok I have the OEM 18's and my tires are at there end. I should of changed them like a couple thousand miles ago!
Anyways I need to buy new tires but there are soooo many choices.
I want a tire that will grip but not ware out after 12K miles. I got 36K miles out of the Michelin Piolet Sports.
As far as my driving style I dont peelout at every light or stop sign. I run hard when its time but for the most part I enjoy the ride. I also drag a few times a year.
These are the 3 tires im stuck with:
Toyo Proxes T1-S
Bridgestone S-03's
I was just going to go with the Piolets since my first pair was soooo good but when I got a quote I was like uhh huh...
Also Im a little confused with the tire size.. Im guessing I should keep the front the same 225/40/18 and the rear 255/45/18?
What do you guys say? Any other suggestions? Please hurry I need to pull the trigger on this ASAP!
Thanx in advance!
Old Mar 31, 2006 | 10:54 AM
MoodDude's Avatar
MoodDude
Go with the PS2's instead. Look at Tirerack rating on them and what others have said about them. KDW's are a great tire too.
Tire sizes depend on the what is avaliable in that brand, and if you still want understeer, or if you want to be able to rotate the tires.
Call Tirerack and ask for Luke and he will point you in the right direction, even if it is a tire he doesn't sell!
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
