Optimal road course setup?
Originally Posted by King Tut
Yeah I am only running 235 width Dunlop SP Sport Race tires all the way around versus my street setup of 245/275 Dunlop SP 9000 tires. I already know that once warm the race tires stick infinitely better than my street tires. Can't wait to hit a couple HPDE events this year.
Running the same size tire/wheel front and rear will also allow you to rotate your tires for more even tire wear. As already mentioned, another huge benefit is a loss of understeer. I have two setups: 17x9.5 5Zigen ProRacer GN+'s with 275/40/17's that I have street rubber on which I am currently running for both street and track, but I also have a set of 17x9 5Zigen fn01rc's that have 275/40 hoosiers on them. I will probably run the hoosiers next time at the track (probably MSR during ZCON) now that I have some camber as I'm currently testing the prototype camber/caster arms made by SPLParts.
Regardless of what you choose, put the widest tires on that you can fit and fine tune the understeer/oversteer with sway bars adjustments, shock settings, and tire pressures.
Originally Posted by phile
Wow, that's quite a drop in tire width compared to your street setup. That relatively narrow compared to what most other people go with for heir track setup. Why did you pick those sizes?
I went with them becausue they are mounted on OEM 18" Touring wheels which are 18x8 so they really can't take a much wider tire than a 235. I choose those wheels because they were cheap and I knew they would fit over my Stoptechs. Remember most guys are using much wider aftermarket wheels and my street wheels are 19x8.5 and 19x9.5 which is why I run the 245/275 setup. Trust me the 235 race rubber will give me plenty of grip.
350Z_Al
Oct 29, 2020 07:44 PM
