I've been looking for some wheel locks that come with a wrench that will clear the pin-sized hole on my ruff racing 278s. Anyone else out there with these rims and have the wheel lock sizes/brand that you used?
I have the same problem. The lug wrench wont fit without scratching the rim because the hole is too small
What kind of lugs are you guys using?
Mcguard? I'm prepping to get the 19" black Ruff 280s, and I have tuner lugs and Mcguard lugs on my existing set of wheels. Not sweating the Tuner lugs, as the wrench "plugs in" to the lugs. The Mcguard tool however is the exterior kind.
The problem is not the lugs, but the factory lug wrench fitting too snugly in the hole which scrapes up the inside of the hole when you are getting to the lugs
