Weird Handling Issues: I'm Stumped
Old May 5, 2006 | 06:49 AM
Faikius's Avatar
Faikius
Originally Posted by Kolia
If it's just to test without electronics, pull the grey connector from the VDC/TCS/ABS module beside of the brake master cylinder in the engine compartment.
Plenty of lights will turn ON in the dash and you won't have any electronics at all interfering. (They all go back to normal once you replug the connector)
Good idea. Will give it a shot this weekend
Old May 10, 2006 | 02:32 PM
350adamZ's Avatar
350adamZ
Red face
Any updates???
I put my wheels on yesterday... so far, no problems. Tomorrow I will take the turns harder ( since I can now).
Old May 12, 2006 | 06:40 AM
Faikius's Avatar
Faikius
No updates as such. I was out of comission with some kind of cold most of the weekend.
The issue did occur for the first time for me on a long sweeping offramp. Previously I'd only encountered it on short, tight turns. This is getting really annoying...
Old May 14, 2006 | 03:22 PM
350adamZ's Avatar
350adamZ
It's dangerous as hell too
Old May 14, 2006 | 04:44 PM
STRETCH's Avatar
STRETCH
Hey guys,
Whenever i'm on track and I go into a turn too hot (with VDC off), it does the same thing. In my opinion it is the VDC locking your brakes, as it has been said before, it still will act up if it feels the wheels are slipping, sometime innacurately. Also (through experience, Im not preaching) I would be careful going too fast on on-ramps to check out if the VDC is doing this, we als have a tail-happy backend!
Stretch
Old Aug 14, 2006 | 10:26 AM
mistico's Avatar
mistico
Did you guys ever get a solution for this?
I don't think it's VDC becaue I have an 06 base model which has the same simptoms.
When taking sharp turns at speed, it feels as if the one of the wheels(fronts) skips and I feel it on the steering wheel. I have an appointment with nissan today but don't have my hoped to high after readinf this thread.
Old Aug 14, 2006 | 11:16 AM
ssawa's Avatar
ssawa
I was one who posted about this earlier and have since replaced my OEM Bridestones with Goodyear F-1 FG-D3's to match my rears and have had no problems whatsoever. My problem apparently was mismatched tires.
Old Aug 14, 2006 | 11:48 AM
mistico's Avatar
mistico
Thanks for the reply.
My car has the stock bridgestones on with only 1800 miles so it must be something else.
Old Aug 14, 2006 | 12:36 PM
Faikius's Avatar
Faikius
I was originally seeing the issue with the stock tires as well. I have since replaced only the rears and the situation hasn't changed. It still only occurs on hard right turns
Best of luck with the dealer I'm still planning to take mine in if I ever get around to pulling the test pipes off.
Old Aug 14, 2006 | 04:41 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Faikius, my 2004 Touring 350 has issues with the outer axle, back ("unusal axial looseness" - basically the fixed end isn't fixed), that's a whole other story as per my other posts, anyway, this also causes it to feel like it's for a split second like the brakes are grabbing or something very similar.
I see that you feel the issue is with the front of your car, irrespective, as one of the other guys said, use your warranty. Keep us posted and don't take no for an answer. Good luck.
Uriyo_
Sep 8, 2021 08:46 AM
350Z_Al
Oct 29, 2020 07:44 PM
kyin
Oct 15, 2015 05:54 AM
