Work VS-XX or Meister S1
N/P man anytime!
You've probably done too many Z's to count and have the technical background to provide accurate information.
I'm looking to get the Work Meister S1's 3 piece gloss black with the polished lip along with Tires. I also plan to lower the car a little, but I have to search on what the consequences are because my Z has VDC.
I been on the Work's website and downloaded the pdf, but I cant read Japanese.
What is the best setup for my car as far as wheel size and drop. I have the stock Brembo's and I want the biggest lip possible from the Work's.
If you can give me a quote or need more info please let me know.
Thanks
All the WORK S1 wheels i get all will work with your BREMBO.
As long as you run 275-35-19 rear then it will be ok with your VDC.(IF) you run a 275-30-19 then there will be a problem with your VDC.I say do a
19x9.5+19x10.5 about 4" lip with 255-35-19+275-35-19.PM me when you ready ok.
rick@status
rick@status
Originally Posted by 3five0_GT
You think you can help me out for my 06' ZR GT?
Thanks
Thanks
rick@status
rick@status
rick@status
rick@status
Is there an easy way to understand offsets?
http://zmodified.com/gallery/display...bum=731&pos=20
All the 9.5+10.5 i get for you will clear brembo-14" stoptech.and this size will need no fender roll with 255-275-35-19.
What are the offsets for the setup you suggested?
Not sure if this is the correct forum for this. Anywayz, I wanted to thank Rick at Status Auto for EVERYTHING. I purchased the Work Meister S1's in Tit. Gunmetal. Sick wheel! Extermely happy with the wheels. Was a pleasure doing business with you. Outstanding service! Item(s) delivered as promised, calls returned, ALL questions answered. Thanks!
THANK YOU! I'm happy you like it.Post some pix when your done ok.
rick@status
rick@status
Just a little info, The VS-XX are a B!tch to clean. You have to clean the inside of the wheel, clean each spoke, dry the little area where the lug nuts trapp water, dry out the rivets around the wheel, drive the car at least 20mph, and do the process all over again to get all the water out of each crevice....I wish i had a air compressor of some kind...=(
