19" tire question
Old May 15, 2006 | 10:46 AM
03Zilverstone's Avatar
03Zilverstone
Default 19" tire question
I'm about to order my 19" x 9.5" and 19" x 8.5" wheels. I've been looking into tires and the ones I'm interested in don't have a 275/35 tire. Would it be okay to run 275/30 in the back and 245/35 up front? Would I encounter any TCS or ABS problems? Also has anybody used this wheel/tire setup? Thanks.
Old May 15, 2006 | 10:51 AM
Zhornet's Avatar
Zhornet
not sure if you will have a problem im thinking maybe with that wide of one up front i went with 295 in the back and 245 in the front with 19" x 10.5 and 19" x 8.5
Old May 15, 2006 | 10:56 AM
Zerk's Avatar
Zerk
I'm not sure a 275 tire can fit on a 8.5" wheel. As far as the rear wheels you'll be fine. I have 275/30, 245/35 on 10.5/9.5.
Old May 15, 2006 | 10:59 AM
03Zilverstone
I feel like an idiot. I meant to put 245 up front.
Old May 15, 2006 | 11:05 AM
Sr. Panza's Avatar
Sr. Panza
I had 275/30 on the back before and had a problem whenever I tried going into a steep driveway. The VDC would sound as if it was working without there being a need for it to. I don't know if it was the tire that caused this or not. I now have 275/35 and not only does it look better but there's more rubber to protect my wheel. Are there any other options for tires that you might want to go with?
Old May 15, 2006 | 11:28 AM
03Zilverstone
The main problem is I don't want to spend $250 per tire. All the 275/35 tires I've seen are atleast that much. Also I don't have VDC, so that won't be a problem.
Does anyone have any pics of a Z with a 275/30? I don't think I'd have to worry about the roads too much here, but I don't want it to look goofy.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
