Need Tire advice, NISMO...ASAP
So i finally got some new wheels for the summer
Bronze Nismo wheels on my Silverstone Car
here are the specs:
Fronts are 18x8.5.Rears are 18x9.5.Offset is +25 front
and +30 rear.Lug pattern is 5x114.3
I NEED TO KNOW WHAT SIZE TIRES TO PUT IN THE FRONT AND REAR??
PLEASE HELP!!!
and any brand of tires???
here are the specs:
PLEASE HELP!!!
Front 245/40/18 Rear 275/40/18 No problems with TCS. I run Michelin PS2
Here are some pics of my set-up
https://my350z.com/forum/media-share/186537-lmgt4-ap-4-pot-bbk-pics.html
https://my350z.com/forum/showthread.php?t=186537
I WENT TO NTB TODAY... the guy was like put 245-40-18 in front and 275-35-18 in the rear because then the car will look even;, he says if you go with the 275 40 18 in rear your car will look higher from top...what should i dooo
I remember reading on a post here that 255/40-18 in the front will also maintain the stagger. They speculated that nismo prob just recommended the 245/40 b/c it was more readily available and cheaper. Apparently someone had done the math and that was actually a better front tire size. Seems it would reduce understeer as well. I'm tempted to go that route.
NzZ
NzZ
The Nismo LMGT4 is specifically designed for the "Z" and the "G". Nismo recommends 245/40/18 Front and 275/40/18 rear. What's the problem
I run Dunlop SP9000s on mine, and am completly satisified.
Lou
Lou
What would a 285 look like on the rear???? and if I did that would going with a 35 ratio vs 40 help with bulge if there will be any at all???
Im gonna try the KDW-2's and they have all the sizes I want
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
