::NISMO Wheels Thread::
Old Mar 4, 2010 | 11:52 AM
  #501
scenehouser's Avatar
scenehouser
Default Nismo LMZ5 (370Z) on 350Z?
Anyone done it?
If so, pix please
Old Mar 4, 2010 | 11:55 AM
  #502
Waiz's Avatar
Waiz
http://www.thenismoshop.com/ikorb.ph...oduct_id=13190
19x9 +45 front
19x10 +30 rear
Uhhh I don't think that's going to look very good.
Old Mar 4, 2010 | 11:59 AM
  #503
cheshirecat79's Avatar
cheshirecat79
The normal 370 or 370 Nismo edition wheels would look much better, IMO.
Old Mar 4, 2010 | 12:04 PM
  #504
Waiz's Avatar
Waiz
FYI..
https://my350z.com/forum/2009-370z/4...ld-photos.html
Old Mar 4, 2010 | 12:06 PM
  #505
scenehouser
rear offset is fine.. a little bit more aggressive than the lmgt4's actually.. front would need 20mm spacers..
lmgt4 in 350z spec are 19x8.5 +25 and 19x9.5 +30
Old Mar 4, 2010 | 12:18 PM
  #506
SnyzzleZ's Avatar
SnyzzleZ
those wheels look awful. along with a lot of other things on the 370
Old Mar 4, 2010 | 12:22 PM
  #507
redline06's Avatar
redline06
ugly wheels imo, LMZ5 < LMGT4 any day
Old Mar 4, 2010 | 12:47 PM
  #508
ITOzann's Avatar
ITOzann
I agree!
Old Mar 4, 2010 | 04:05 PM
  #509
Luong's Avatar
Luong
So I'm dropped on Eibach Sportlines w/ 18x9.5 +30 all around. Running 275/35/18 all around too. Trying to figure what size spacers I need to run to be flush and I'm willing to roll my fenders. From what I've seen I can run a 20-25MM in the rear, but there's really been nothing I can go on as far as the fronts go. Anyone able to chime in with some knowledge before I start ordering some and test fitting?
Old Mar 4, 2010 | 04:08 PM
  #510
Waiz's Avatar
Waiz
20mm all around should look pretty nice and won't need any front fender modification.
You will most likely need to mod the rear fender though.
Old Mar 4, 2010 | 04:22 PM
  #511
AadosX's Avatar
AadosX
Waizzz, he has the 9.5's in the front too so I'm pretty sure he will need a different sized spacer. It's simple math though...
Let's see... 8.5" width with +25mm offset vs. a 9.5" width with +30mm offset. 1" is roughly 25mm so 1/2" difference on the outside of the wheel pushes it about 13mm farther out than the 8.5, if they had the same offset. But the 8.5 has a 5mm offset difference, bringing it back in 5mm.
So overall you're looking at the 9.5" +30 wheel sitting about 8mm closer to the fender than a 8.5" +25 wheel.
In that case I suggest a ~10mm spacer for the front.. but that will cause issues for you because it's tough to get spacers in that size that are hub-centric, if that matters to you.
I just test-fitted my 20mm spacers on one side today and decided that I'm probably going to go with 20mm rear and 15mm front. It's not too aggressive but IMO my car isn't low enough for very aggressive final offsets (Eibach Pro-Kit). I will get some pics up later! I definitely want Sportline's =P
Old Mar 4, 2010 | 04:46 PM
  #512
nissanzealot's Avatar
nissanzealot
How much is a good set of LMGT4's, I've always wanted some
Old Mar 4, 2010 | 04:53 PM
  #513
Luong's Avatar
Luong
Thanks for the help! So it sounds like 10MM Fronts and 20MM Rears to be flush. Appreciate that I was going to buy 20MM Fronts and 25MM Rears haha.
Old Mar 4, 2010 | 05:15 PM
  #514
Luong's Avatar
Luong
Just ordered a set of 20MM from a member here, well see how they look whenever they get here
Old Mar 4, 2010 | 06:08 PM
  #515
Thermal1's Avatar
Thermal1
4 rears might be sweet... but no way will the 19x9 +45 fronts look good on the Z
Old Mar 4, 2010 | 07:51 PM
  #516
AadosX's Avatar
AadosX
Ok first are before pics. Note that I only own one pair of 20 mm spacers for now so I just put them on one side to get pics.
And now for after pics. In person I thought the front looked too aggressive with 20 mm spacers at my ride height (dang I want lower springs! lol).. but now looking at the pics I'm starting to lean towards putting the 20 mm up front and maybe getting 25 mm for the rear. Can't decide...
So what do you guys think? For now I just have both of the 20 mm spacers installed in the rear... no pics yet though.
I dunno, maybe 20 mm all around is the way to go. But really, lowering the car more is the way to go! =/ There is just too much wheel gap back there.
Oh and I definitely rub but only on the biggest of bumps/dips. I cringe though fearing I'm cutting into my tires. Need to get my rear fenders rolled ASAP! Hrmm, how am I going to go about doing that?...
P.S. Yep looks like it's almost time for new rear tires. =P
P.S.S. Damn gas is expensive.
Old Mar 4, 2010 | 08:08 PM
  #517
Waiz's Avatar
Waiz
Luong, you won't be disappointed.
I'm running 20mm all around, although I'm on 19"s
Old Mar 4, 2010 | 08:13 PM
  #518
Luong's Avatar
Luong
^ Yeah I remember seeing your set up, I fell in love with it at first sight haha. Thanks again for your help guys. I can't wait till the one set arrives.
Old Mar 4, 2010 | 08:14 PM
  #519
Waiz's Avatar
Waiz
HAHA, thanks dude.
GL and post up pics when you get it installed.
Old Mar 4, 2010 | 08:16 PM
  #520
Waiz's Avatar
Waiz
Atta boy
