Work Rims
Old Jun 28, 2006 | 11:58 AM
supra crazy's Avatar
supra crazy
Default Work Rims
Hey I bought Work equip 01s used but I got into an acedent and messed up the lip. I wanted to know do companies sell only the lip or would i have to buy the whole rim again. I beleive it has been discontinued. but it is a 2 peaice and i can separate the spoke from the lip.
Old Jun 28, 2006 | 03:04 PM
A Spec Products's Avatar
A Spec Products
I assume you mean the 18" Equip 01s, which yes, sadly have been discontinued.
If the lip cannot be fixed by a wheel repair shop, then maybe try seeing if you can just replace the barrel:
http://www.kodiakracingwheels.com/shells.html
Some people here in the states have used Kodiak, maybe give it a shot.
Good luck!
Old Jun 28, 2006 | 07:47 PM
supra crazy
I would need the inner lip wouldnt it be that same as the work Meisters S1?
Old Jun 28, 2006 | 07:50 PM
Zexy's Avatar
Zexy
Post pics of the damage. If it's not that severe it can most likely be fixed.
Old Jun 28, 2006 | 09:42 PM
A Spec Products
Not necessarily. I think it would be pretty hopeless to try to order replacement parts directly from Work. I can double check but I don't even think its possible.
Take the wheel to a professional wheel repair shop, they can give you an estimate and tell you if / if not its fixable. And usually they are mad conservative so the answer you get is the safe and right one.
_bit
Oct 2, 2015 07:49 AM
