I think I am gonna rub
Old Jul 19, 2006 | 01:07 PM
Pac Man's Avatar
Pac Man
Default I think I am gonna rub
I've got an 05 Enthusiast lowered on Eibach Pro-kit springs. I've also got some Work Emotion XD9's which the UPS guy just brought--18x10+18 and 18x9+20.
Anyways, the problem is I think I'm going to rub. I understand some tires run a little wider while others a little narrower. The sizes I am interested in are 275/35 and 255/35, and most likely T1R's.
Should I plan on rolling the fenders?
Old Jul 19, 2006 | 01:47 PM
A Spec Products's Avatar
A Spec Products
I would just put it on and if they rub, roll em
If they don't then cool
I don't think you should have an issue
Old Jul 19, 2006 | 02:02 PM
Pac Man's Avatar
Pac Man
Yup, your right. I just think it's going to be a tight fit. But anyhow, we'll just have to wait and see.
Old Jul 19, 2006 | 03:45 PM
plastiketa's Avatar
plastiketa
I'm getting some 19' Meister S1s 9.5 front, 10.5 rear, 1in drop all around. Think I'll rub?
Old Jul 19, 2006 | 04:00 PM
A Spec Products
Most likely, unless the offset was super high or something.
Old Jul 19, 2006 | 07:43 PM
kenttz's Avatar
kenttz
You might not rub , I myself am running 18x10 +13 with 275/40/18 and just barely rubbed. If it does rub it wont be that much, and I would just roll them in abit. Also you are thinking of getting a 35 series tire which is 5mm less tall compared to mine , so you might be in the clear but just barely.
Old Jul 19, 2006 | 07:49 PM
touge_g35's Avatar
touge_g35
I'm running 19" Meister S1's 9.5 front and 11 rear, with 2" front and 1.5" drop rear. I am not rubbing at all after alignment. The car only started rubbing on the inside when making a turn up a driveway when the springs settled due to bad negative camber in the rear. But Westend Alignment fixed all that.
Old Jul 19, 2006 | 07:50 PM
Zexy's Avatar
Zexy
You won't rub.
Old Jul 19, 2006 | 08:33 PM
Z33Benny's Avatar
Z33Benny
you shouldnt have any issues with those sizes and offsets.
Old Jul 19, 2006 | 09:14 PM
ppw350Zunit's Avatar
ppw350Zunit
you shouldn't rub.
Old Jul 20, 2006 | 05:58 AM
Pac Man's Avatar
Pac Man
Everyone, thanks for the input. I'll be sure to let you know how it turns out.
Old Jul 20, 2006 | 06:01 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I think you will rub on hard cornering or very bumpy roads, or be so close that I wouldnt risk it. You can have your fenders rolled for around $150, I suggest you do it, and sleep better at night...
Old Jul 20, 2006 | 09:17 AM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
If you run 245/275 you should be more than fine...
Old Jul 20, 2006 | 09:57 AM
ultraxr's Avatar
ultraxr
Since this thread is going... instead of me starting a new one. =)
My question is: I got a set of Lexion x503 19x9+25offset/19x10+20offset (bought from a member on here) I plan on wrapping them with some 245/35/19's-fronts and 275/35(possibly 30)/19's-rears. I was wondering if i was gonna go with some springs instead of a coilover set up. what kinda drop would i be good with that closes up most/or all the gap WITHOUT rubbing? Suggestions please. thanks guys.
Old Jul 20, 2006 | 07:14 PM
Alberto's Avatar
Alberto
Cranky FI Owner
^^If I had to guess, Id without a doubt say Hotchkis(less than 1" drop but loks good IMO), but for $150 or less why not roll?!
Old Jul 20, 2006 | 07:22 PM
ppw350Zunit
a buddy of mine is dropped on hotchkis and he has 19x9 +25 offset, 19x10 +24 offset, 245/35 and 275/35 and he doesn't rub.
Old Jul 21, 2006 | 04:45 AM
Alberto's Avatar
Alberto
Cranky FI Owner
^^ Yeah but 4mm makes a huge difference when the clearances are so tight. Your buddies wheel sits further in away from the fender...
Old Jul 21, 2006 | 05:19 AM
ultraxr's Avatar
ultraxr
what did you mean by "...for $150 o less why not roll?!"
Old Jul 21, 2006 | 10:00 AM
plastiketa's Avatar
plastiketa
+1 on Westend! Thats where I plan on going once my setup is complete. Just waiting for rims and front a-arms.
Old Jul 21, 2006 | 10:03 AM
plastiketa's Avatar
plastiketa
offsets: +24 front, +29 rear
