tire preasure??????????
Old Aug 10, 2006 | 04:00 PM
nasty50's Avatar
nasty50
Default tire preasure??????????
this is pretty stupid but here it goes.i got a 06 350z and thinking of changing the wheels.what do i have to wory about as far as the wheels sensor?
Old Aug 10, 2006 | 05:06 PM
DavesZ#3's Avatar
DavesZ#3
1) Will they fit?
2) Did I move them from the old wheels to the new ones and keep them on the right corners?
That should be all you have to worry about.
The TPMS sensors don't automatically fit all aftermarket wheels. If they don't fit the wheels you buy in the normal fashion (through the valve stem hole), you can always used the banding method described in the sticky at the top of this forum.
If you don't keep the sensors on the proper corners of the car, then they won't be displaying correctly in the display. For example, the Front Left pressure may be reading the pressure from the rear right wheels if you get the sensors mixed up.
Old Aug 10, 2006 | 10:48 PM
nasty50's Avatar
nasty50
well iam concern about ordering wheel from one of our vendors allready mounted and ballanced.will this be okay?or do i have to specify i need the sensors?
Old Aug 11, 2006 | 03:52 AM
DavesZ#3's Avatar
DavesZ#3
If you're buying a combination, then you're kinda' screwed as far as the TPMS sensors goes. They aren't going to provide any so you'll be riding without them. If you want to keep the ability to monitor your tire pressure, you're going to have to get somebody to brake the bead on one side, install the sensors then re-seat the tire.
A lot of people just don't put the sensors back in and learn to live without the capability.
Old Aug 11, 2006 | 06:58 AM
nasty50's Avatar
nasty50
thats good to know.thanks man.
but if thats the case i can get the one from the stock wheels and transfer right?
Old Aug 11, 2006 | 09:25 AM
DavesZ#3's Avatar
DavesZ#3
Yes, you want to transfer the stock ones. The sensors are "registered" to the computer in the car. If you get new sensors, those have to be registered to the cpmputer or they won't be recognized. When you do that, the old sensors are no longer recognized. It's best to stick with the stock ones.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
