Volk LE37T help
Old Aug 17, 2006 | 11:43 AM
drivenCSZ's Avatar
drivenCSZ
Default Volk LE37T help
not my question, just trying to help somebody out...i didnt have the answer though. I know the common offset would be +22 though, correct?
Does anyone know if these will fit good on my Z?
# Front Rims: 19x8.5, +43 offset, 5x114.3 bolt pattern
# Rear Rims: 19x9.5, +45 offset, 5x114.3 bolt pattern
# Tires: Michelin Pilot Sport 245/35-19 front, 275/30-19 rear
They're 19" Volk LE37T for $2400 used.
They're in great condition. One rim was
repaired from the lip getting bent in a pot-hole.
Is it a good deal?
thanks.
Old Aug 17, 2006 | 11:44 AM
Z33Benny's Avatar
Z33Benny
those are g35 sedan offsets. You could use some 20mm spacers with them and they should fit fine though.
but yes... volks with tires, thats a pretty good deal, the wheels alone cost about that much new.
Old Aug 17, 2006 | 11:52 AM
Nexx's Avatar
Nexx
you'll need spacers. with that tire setup, your tcs and or vdc will go off from time to time.
Old Aug 17, 2006 | 12:00 PM
Brick-Z's Avatar
Brick-Z
S***ty offsets for our Z's.
Old Aug 17, 2006 | 01:07 PM
josephchihweilu's Avatar
josephchihweilu
yea those are weird offsets. does anybody know if 9.5 front rims with +15 offset will fit nicely on Zs? Im not really sure about this one.
Old Aug 17, 2006 | 01:13 PM
gimpster621's Avatar
gimpster621
that might be stretching it. im running le37's 19x9.5/10.5 +22's. fronts barely tuck in.
Old Aug 18, 2006 | 09:25 PM
NISMOFO's Avatar
NISMOFO
I'm running the same offsets & sizes. I would say this is the perfect setup for LE37T's or TE37's as long as you're dropping your car.
BTW gimpster621, you're car is bad ace....more pictures?
Stevo Z
Oct 3, 2015 09:14 PM
