LE37 with offset +12?? HELP needed
Old Sep 2, 2006 | 06:59 PM
josephchihweilu's Avatar
josephchihweilu
yea ive seen +12 being run up front...thats the lowest offset ive seen so far though for a 9.5 inch rim up front.
Old Sep 3, 2006 | 10:28 AM
drumma022's Avatar
drumma022
I was running x9.5 +11 and x10.5 +11, but had standard brakes. Camber was not overwhelming as I was running 235/35/19 and 265/30/19. This was also using only the stock toe/camber adjusment points.
Old Sep 3, 2006 | 11:41 AM
ActionJackson's Avatar
ActionJackson
Yeah, +11 or +12 won't really make the front tires stick out as much as people are saying. In fact by lowering your car the camber will adjust itself and tuck in. If you run a 245 tire in front it won't rub either.
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
