okay need offset/spacer help
Old Sep 3, 2006 | 06:44 AM
kaybee650's Avatar
kaybee650
Default okay need offset/spacer help
i have 17x8.5 +35 for all 4 corners of my car.
245/40 in the front
255/40 in the rear
so i need spacer help please,
Old Sep 3, 2006 | 07:55 AM
zillinois's Avatar
zillinois
245/40 in the front
255/40 in the rear
You are sitting within a couple of millimeters of stock right now. If you want it to look more aggressive, 25mm/1" spacer would bring the wheels out nicely.
Old Sep 3, 2006 | 08:14 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
are you saying to add +25 all around?
Old Sep 3, 2006 | 10:33 AM
drumma022's Avatar
drumma022
If you would like an aggressive setup .. yes run 25mm front and maybe even a 35mm spacer rear!
Old Sep 3, 2006 | 03:19 PM
Kolia's Avatar
Kolia
245/40 in the front
255/40 in the rear
No you don't need spacers.
If you have a Z that is. Don't know about Civics and such...
Old Sep 4, 2006 | 10:02 AM
Osix350Z's Avatar
Osix350Z
What do you mean he doesn't "need" spacers? his offsets right now are pretty fuked... A spacer would help bring the wheel more flush with the fender, giving it a wider more agressive stance. Stock offsets look horrible on the Z.
Old Sep 4, 2006 | 02:25 PM
jrotaryb's Avatar
jrotaryb
the only problem with a spacer that big is that when the car is still, it is blatantly obvious you have the spacer
Old Sep 4, 2006 | 02:56 PM
Kolia's Avatar
Kolia
Ah yeah, I guess it would "look" better with Mexican wheels sticking out of the fenders too ?
+35mm offset is close enough to stock. Believe it or not, offset is actually a factor in suspension design. Handling wise, wider is not necessarly better. Certainly not on the rear. That's if you want your car to corner of course...
If "prettyness" was what the OP wanted, I doubt he would drive around with 245/40R17 and 255/40R17. 19in rims would look better IMO...
Old Sep 4, 2006 | 08:27 PM
What kind of spacer help?
What is wrong with the way that the car performs as is?
Do the wheels clear the brakes?
Old Sep 5, 2006 | 08:29 AM
tHisZ_bFAST's Avatar
tHisZ_bFAST
Oh....that's racist.
Old Sep 9, 2006 | 08:25 AM
kaybee650's Avatar
kaybee650
the reason being i just want to make sure i dont have abnormal tire wear. i have two sets of rims
the 17x18.5 offset +35
and my usual 18inch staggered setup 18x8.5 and 18x10.0.\
i havent really gotten around to put more than 30 miles on the 17" set-up but acceleration is increased and handling is increased because i am using advan ao48's..
my knee has been swollen for 5 days now. so ill let you guys know of the tire as well.
Old Sep 9, 2006 | 08:51 AM
zillinois's Avatar
zillinois
Spacers are for cosmetic purposes, they are not for correcting camber issues. Plus, I don't think you will have a problem because your tire sizing is probably very close if your 18's have a lower profile.
Old Sep 9, 2006 | 09:02 AM
Spacers have no relation to tire wear. If the wheels clear the brake calipers leave them alone.
