Rim/Tire
Old Oct 23, 2006 | 04:48 PM
Built2shredZ's Avatar
Built2shredZ
Default Rim/Tire
A member wanted me to post these pictures to get an idea of how the rim/wheel looks from behind...
Because of the camber, the bottom of the wheel acutally sits outside the wheel well where the top of the tire is tucked inside of the wheel well... You could use spacers to push the rim out further but if you go to far then you will need to roll the fenders. You could also buy a camber kit and straighten up the rim but then you will lose some handling but possibly gain longer life for the inside of the tire...
BTW dimensions are
Front: 19x9 (245/35-19) +31mm Offset
Rear: 19x10.5 (275/35-19) +43mm Offset
Attached Thumbnails Rim/Tire-wheel-1.jpg   Rim/Tire-wheel-2.jpg   Rim/Tire-wheel-3.jpg
Old Oct 23, 2006 | 05:04 PM
RyanZ33's Avatar
RyanZ33
Thanks for doing this for me man!
Your Z is very sharp!
Ryan
tpain
Wheels Tires
Mar 21, 2015 08:27 AM
showspeed
Mar 21, 2011 01:02 PM
