smallest rim size for the Z (winter)
Old Oct 24, 2006 | 09:03 AM
[]V[]addog's Avatar
[]V[]addog
Default smallest rim size for the Z (winter)
I;ve been going back and forth between getting a beater and buying winter tires. I know either way is gonan cost me. But what I haven;t been able to find while doing a serch is the smallest rim size you can buy. Obviously the smaller they are the cheaper the winter tires will be. I have found an alomst new set of winters that were on a police cruiser. But they are 16 inch wheels, will those clear the break, or do i have to use 17 inch? I have the 03 touring model with the stock 18 right now, i'd rather not buy a 18 inch winter tire...
any help woudl be much appriciated.
Old Oct 24, 2006 | 09:26 AM
sry110's Avatar
sry110
Yeah brake clearance might be an issue. Worst case you might need to get some spacers to push the wheels out. I just bought, from Tire Rack, a set of SSR Comp-H wheels 17" x 8.5" wide, +31mm offset with 225/50/R17 front tires and 235/50/R17 rear tires. The tires I bought are Bridgestone Blizzak LM-22's which I understand to be pretty good in the snow. The SSR Comp's were listed by Tire Rack as a wheel that fits a 2006 350z enthusiast, so I am assuming that there will not be a problem clearing the stock brakes (although I have not test fit them first-hand yet).
I went through the same dilemma: buy a beater or spend some real money on a set of winter wheels/tires? The solution I came to is this: Considering the climate here in southern Pennsylvania, I will probably only run these wheels/tires for 3-4 months of the year. At about 1300 miles that I drive each month, I will rack up 5200 miles per year. I figure I can get about 25,000 miles out of a set of tires so that means every 5 years I need to put out 600 or so for new tires. The wheel and tire package I bought set me back $1450.00 USD which gets me through 5 winters per the above logic.
The other option is to buy a beater for at least $1450.00 USD then pay a little more each month to insure it, pay to maintatin it, find a place to keep it during the warmer months (which is an inconvenience for me personally) and some other reasons. The way I looked at the beater concept is that I would be basically buying a set of winter wheels and tires with a car attached to it, and consequently I would be committing myself to take care of the car, when all I really wanted to do was purchase something that allowed me to get from point A to point B in snowy conditions, i.e. winter wheels & tires.
So that is the choice I made. Now I only have to store a stack of wheels/tires instead of an entire car. And I do believe that in the long-term it will be more expensive to own and maintain a winter beater than to have a set of winter wheels and have to replace tires every 5 years or so.
Old Oct 24, 2006 | 09:40 AM
sry110's Avatar
sry110
Oh and to focus in closer to your question, I decided not to go below 17" wheels because while saving money would be nice, part of the reason I bought this car was because it looks so damn good and I didn't want to completely sacrifice its appearance just to save a few bucks on the winter wheel package. I think 16" might look pretty tiny, and those tires are going to look like doughnuts on there. If you are looking at wheels/tires vs. beater, I think price wise you can make out a lot better on a set of 17" wheels and tires....maybe even 18", depending on the age and quality of the beater you are looking at.
Old Oct 25, 2006 | 06:09 AM
[]V[]addog's Avatar
[]V[]addog
well i'm from the east coast of canada, and we get ALOT of snow.. so i'm not really in the same situation as you.
And i can get a nice reliable 10 year old honda for 2000 bucks, canadian. Parts are a dime a dozen, easy to find, easy to fix, and the engines are buletproof. easy on gas....
I didn't think 16 inch wheels woudl fit, and In the winter iu'm not worried about looks/performance, it;s always snow, dirty, sandy ont he roads...
so... while yo may pay to fix your beater, I won;t have to worry abotu exposing my Z to the salt and sand for 5 months.... it;s a trade off for sure. But if i want my Z to last... i think i'm actuly leaning the other way.
cheers
Old Oct 25, 2006 | 06:36 AM
I recommend 17x7 inch wheels with the proper offset.
Old Oct 25, 2006 | 08:10 AM
sry110's Avatar
sry110
Yep I understand that also. If I had a garage or some place to store a spare car I may have gone that route, if only to protect my black Z's paint from hundreds of little rock chips.
Old Oct 26, 2006 | 10:59 AM
[]V[]addog's Avatar
[]V[]addog
exactly, i'll have the Z in a nice heated garage, away fromt he elements
found and old volvo for 500 bones
3vilbunny
Jul 18, 2017 05:10 PM
ablaine
Nov 29, 2016 10:13 AM
