AhHhh Tire Sizessss
I have the volk time attack te-37's 9.5 front 10.5 +22 rears offset all around on order and im debating on tire sizes. I know im beating a dead horse ut what do you guys recomend. Im going with the BFG TA's Drags
245/35 or
255/35 front
275/35 or
285/35 rears ???
Id like to run 285's but I dont know if the 285/35 would rub like crazy.
and if I do run 285/35 in the rear is 245's in the front to small in comparison.
I dont want to rub to much in the front concidering im gana slam the car pretty low to where its still functional.
what do you guys think ???
245/35 or
255/35 front
275/35 or
285/35 rears ???
Performance Nissan
Performance Nissan
Originally Posted by 350Zteve
If your car is lowered, 285's will rub non stop on a +22 10.5" wheel. Even 275's are going to rub on that offset, just not as bad.
Thank you for confirming that andy .. ill go with the 275's since its been done before with exact measurments. Do you mind telling me if you run with a spacer. I was thinking of getting a 15mm spacer for the rear. I saw it in a couple photos and it really positioned the rear wheels in an aggresive location.
Performance Nissan
Performance Nissan
You can run a 15mm spacer front and rear if you want but you will definitely need to roll your fender cause it will rub. My rear actually does rub now but its cause of the new suspension.
Thanks guys .. yea i think im gana try to do a 15mm spacer in the rear to really give it that aggressive look. Should work out great .. ill post pics as soon as I get my dang wheels in from Japan already. Im about to go get them myself
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
