18x8 all around +35 offset ok?
Saw these and really like 'em. Question is, will they fit okay? I have an auto touring with the 17s. Was looking for stock 18s until I saw these. Anyone feelin' these?
Anyone heard of Forte? They any good? Also, the label on the box shows C.B. as 73mm, what the heck is that?
CB is centerbore... I think the Z CB is around 67. You will just have to use the rings that come with the wheels(usually). The only thing is I don't think a 35mm will look good on the car. I just put on 8" wide in the front and 9" on the back with a 25mm offset and they still stick in a little, so just imagine over 10mm more... And I had the 17's. I would try to find a wheel with a 30 or less offset...
The wheels you have are 17x7.5 +30 offset front, and 17x8 +33 offset rear. You can use the offset calculator near the top of the wheels & tires forum to see how a set of aftermarket wheels will compare.
And yeah, it's had to find wheels with the correct offsets - less than 35.
DarkCreep
Oct 17, 2015 11:50 PM
