PICS:new wheels! 18x8.5 +10mm all around Axis hiro
Ive had the wheels for a while, but finally got some spacers put on. I put h&r 25mm on all four corners to bring them to +10 all around. Im thinking of upping the rears by 5-10mm to bring the stance out.
Wheels are axis hiros in anthracite. 18inch by 8.5 all around and run 245/40 falken ziex ze 512. VDC is ok with it, so i dont want to hear about it.
pics:
pics:
opinions? how much more should i go out with the rear? Ill be running 245 tires always, no need for wider rubber.
more:
more:
It's weird...since the front tire is so pushed out the rear tire looks stretch on the rim. An illusion created by how it sits in the wheel well I guess.
I'm not sure I would personally want to use anything larger than a 25mm spacer before considering other options...but if you insist on a non-staggered setup, yeah 5-10 more mm would look better.
i can fit fatter tires on them but theres no need. I also rotate(front to back) my tires but its a dd.
And with how fast i run through tires, wier ones would cost too much!
I got the rims cheap, like 800 shipped brand new.
https://my350z.com/forum/attachment....5&d=1172867653
In this side shot the rear tires look taller like a 245/45.
