Back Tires Go bald on inner edge?
This is happening to my back tires. The inner edge is wearing a little bit more than the middle and sides. Is this normal? I have stock suspension. Camber adjustment arms?
I have Toyo T1R's and put about 17K already.
Yeah, pretty normal. Tire pressure? I run about 33 in the rears cold.
You can rotate the tires if you have a buddy that will swap them around for you. I usually go in and have them swap the tires every 7500 miles.
edit, i thought it was normal.
I run about 35 in the rears cold. Right now it's runnign 38-40 hot. How long are they supposed to last?
should i get these?
http://cgi.ebay.com/ebaymotors/RearU...spagenameZWD1V
should i get these?
Depends entirely on your driving style and maintenance schedule. I think T1Rs are rated at 30k, but I could be wrong. I have them as well and after 7k, tread depth is still at almost as-new levels. My factory alignment was way off and I had to get it adjusted at just 2k mi. Dealer covered it under warranty.
If you are lowered and have introduced more negative camber than stock then you might want something like that. Otherwise I'd leave it as is, unless you are only concerned with straight-line acceleration, those will give you a better contact patch for that.
Is it just me or is it kinda funny that "Just-Intercoolers" sells suspension parts.
should i get these?
should i get these?
I would definately not buy those, 55 bucks....they can't be any good. I don't htink it is right to judge by price, but when it comes to being that abnormally cheap...i would stay away. Get the spc arms and bolts if you want to mess with cabmer without forking over 600 for two sets of arms. As i understand it, if you mess with the camber you must change the toe also. Changing camber also changes toe the way our cars are set up. You must change the camber and then adj the toe back into spec, or wherever you want it.
There are some spc camber arms and toe bolts for sale on here and also look at the vendors section, i think there is a sale. I think i paid about 200 for mine.
Originally Posted by davidv
Photos are always helpful.
http://www.drivingfuture.com/blog/ne...e-20050404.jpg
http://www.hotrod.com/featuredvehicl...+bald_tire.jpg
350Z_Al
Oct 29, 2020 07:44 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
