View Poll Results: Offset
30mm
15.56%
25mm
33
36.67%
20mm
43
47.78%
Voters: 90. You may not vote on this poll
Which rota setup should I get?
Old Dec 18, 2006 | 06:53 PM
solidsnake's Avatar
solidsnake
Default Which rota setup should I get?
Ok I know for sure I want 9.5 all around but I cant decide on the offset. Currently subydude tells me he has them in stock but only in 30mm and 25mm offest. I wanted 20mm. What do you guys think will look best? Basically I do not want a (cave in) look and have to be forced to use a spacer because I hate the spacer idea. Im not slammed because I only have the hotchkis springs and dont lower as low as eibachs.If you rota guys have pics please feel free to post them up. Thanks!
Old Dec 18, 2006 | 07:03 PM
solidsnake's Avatar
solidsnake
here is what +20 looks like and this is what im leaning towards.
Old Dec 18, 2006 | 07:33 PM
JDMFairlady21's Avatar
JDMFairlady21
stick the +20s the +30 is def out of the question, you'll want a damn spacer with it...
Old Dec 18, 2006 | 07:34 PM
solidsnake's Avatar
solidsnake
yeah +20 looks the best .im sure ill have to roll the fenders but that isnt a big deal.
Old Dec 18, 2006 | 07:44 PM
MrGoingdown305's Avatar
MrGoingdown305
you aren't going to need to roll the fenders...
Old Dec 19, 2006 | 05:34 AM
WalkerT's Avatar
WalkerT
Professional
mine are +25
Old Dec 19, 2006 | 01:51 PM
Brick-Z's Avatar
Brick-Z
Forget the 30mm offset. Whats the problem with the 25mm?
Old Dec 19, 2006 | 03:36 PM
UR NZWY's Avatar
UR NZWY
Originally Posted by walkert
mine are +25
Can you post some more pictures? CLose ups, angles, etc!?
Old Dec 19, 2006 | 05:26 PM
solidsnake's Avatar
solidsnake
mine are +25
what tire sizes? can you ake close up pics and rear views
Old Dec 19, 2006 | 06:32 PM
WalkerT's Avatar
WalkerT
Professional
https://my350z.com/forum/wheels-and-tires/231523-new-wheels-p45r-rota.html
Here are some more pics and the info on tires.
Old Dec 19, 2006 | 07:03 PM
Cheezwiz's Avatar
Cheezwiz
The higher the offset, the more the wheels stick out. So I'd lean towards +30mm. But if Solidsnake's got 20mm, they look pretty damn good.
Old Dec 19, 2006 | 07:09 PM
WalkerT's Avatar
WalkerT
Professional
The pic is of subydudes black Z and he had to roll the fenders but he is running 305 rear with +20 I have 285 with a +25 I have just enough room.
Old Dec 19, 2006 | 07:46 PM
97supratt's Avatar
97supratt
I have the 30mm, but i put a 25mm spacer in the rear. Here is what it looks like....
Old Dec 19, 2006 | 10:03 PM
UR NZWY's Avatar
UR NZWY
So If I wanted to get hte 9.5 around, the 30 mm offset would make the wheels stick out more/?
I want these wheels, but I want to avoid the wheels looking tucked in
Old Dec 19, 2006 | 10:09 PM
plumpzz's Avatar
plumpzz
You'll want a 25 because 20's will limit ur tire sizes if you're lowered. With 25's you can fit bigger tires and also be lowered more. 20+ and you're gonna start to throw off suspension specs. 30+ and you're gonna have poor fender filling.
Old Dec 19, 2006 | 11:15 PM
Triple8Sol's Avatar
Triple8Sol
+20 all the way
Old Dec 20, 2006 | 12:23 AM
UR NZWY's Avatar
UR NZWY
Thanks, +25 it is!
Old Dec 20, 2006 | 06:06 AM
DustinZ33's Avatar
DustinZ33
Wrong. If you get +30mm offset, your wheels will tuck more. Basically the + 20mm offset will stick out 10mm more than the 30mm from the hub. Check this out, it might help. I found this in another thread. http://www.1010tires.com/WheelOffsetCalculator.asp
Old Dec 20, 2006 | 07:04 AM
97supratt's Avatar
97supratt
I think +20 is perfect. If you want to go more aggressive, you can get a spacer. Mine is very aggressive especially with the 275's in the rear. My fenders are rolled though, so a 20mm no spacer for your car should be fine.
Old Dec 20, 2006 | 07:15 AM
NA&CH's Avatar
NA&CH
Car looks sick 97. Keep it up.
