350z and NSX
Old Dec 27, 2006 | 06:47 AM
NIzzanturboka's Avatar
NIzzanturboka
Default 350z and NSX
does any one no if a set of hre's that i have on my 350z. will fit an acura nsx.... i think the two car have the same lug patern... please let me no
Old Dec 27, 2006 | 07:46 AM
NIzzanturboka
bummmmppp anyone?
Old Dec 27, 2006 | 07:53 AM
sanf's Avatar
sanf
do a search in google of the bolt pattern/off set .. that should do it for u
Old Dec 27, 2006 | 07:56 AM
Nihilation's Avatar
Nihilation
My NSX ran 18x9's with a 38 offset in the rear, 17x7.5's in the front with 40 offset. If anything you might be able to run the rear NSX wheels on the front of your Z.
Old Dec 27, 2006 | 08:32 AM
NIzzanturboka
NSX 1991-2004 5 x 114.3 12 x 1.50 +55
350Z 2003-2004 5 x 114.3 12 x 1.25 +35
wat i mean is i have a 350z but i wanna buy a nsx .....i have a set of HRE on my Z and i want to know if they would fit the NSX ... i no they will bolt on but will they stick out or stick in
Old Dec 27, 2006 | 08:39 AM
Nihilation's Avatar
Nihilation
What size HRE's? A 9.5" wide wheel with a +35 offset is probably about the max you'd want to run on the rear of a factory bodied NSX iirc. You can't fit much more than an 8" wide wheel on the front of an NSX unless you run wider fenders.
Old Dec 27, 2006 | 09:06 AM
NIzzanturboka
i have 20 +8.5 and a 20+ 10 in the rear there hre 542....do u think they fit fine
Old Dec 27, 2006 | 09:08 AM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
More than likely the offsets will not good for the Z.
Old Dec 27, 2006 | 09:11 AM
NIzzanturboka
wat did u rite???
Old Dec 27, 2006 | 09:21 AM
Nihilation's Avatar
Nihilation
I think he says he has those HRE wheels on his Z now but wants to know if he can put them on an NSX. The answer is most likely no, NSX's need a perfect offset to fit an 8.5 front wheel, it's rarely done and even if it is they're stretching a 225 or 235 max tire on it. If anything your 20x8.5's wheels MIGHT work on the rear of an NSX if you're lucky.
Don't do it, just sell them and get proper fitments. 17/18 or 18/19's for an NSX.
Old Dec 27, 2006 | 09:24 AM
NIzzanturboka
i seen it done... my 20's look like 18 cuz of the 2step lip...... so do u think the will stick out or stick in on the nsx
Old Dec 27, 2006 | 09:57 AM
Andy@Performance
Performance Nissan
The NSX uses high offsets so if you put them on a Z it will stick way too in.
Old Dec 27, 2006 | 10:20 AM
sanf's Avatar
sanf
the Z wheels on the NSX might stick out more. if anything.. just roll the NSX's fender or throw a wide body on it for deeper dish rims
Old Dec 27, 2006 | 11:17 AM
NIzzanturboka
thankss yea i confirmed it it will stick out a hair but i am gonna gett them rolled
Old Dec 27, 2006 | 05:08 PM
Volk350Z's Avatar
Volk350Z
Master
so you have 20" on your nsx right? well when i sell wheels to nsx i normally put 18x8.0 +38 or higher & 19x10.5 +45 or higher offset..
Just to let you know the 8.5 will rub the suspension arm when you turn..
If you dont mind me asking the exact spec on the HRE wheels..
Old Dec 28, 2006 | 05:35 AM
NIzzanturboka
no mann read the thread.... i have a nissan 350z with 20 hre 8.5/10+20 on the car rite now i want to buy and NSX but i am not sure if the wheels will fit .. i no they bolt on but i wanna know how much will the pop out or if i can even drive with them
Old Dec 28, 2006 | 08:49 AM
Volk350Z's Avatar
Volk350Z
Master
well normal people put 20x8.5 +20 & 20x10.0 +20.., well with that setup you will stick out about 25mm (1in).. you can use that setup on your nsx if you have a widebody kit..
Old Dec 28, 2006 | 09:18 AM
NIzzanturboka
wat about if i roll the fenderson the nsx will it work.....rite now the hres on the 350z are siting nice.....the front rims are in a lil bit
(not flush with the fender) and the rear is flush with the fender
Old Dec 28, 2006 | 09:26 AM
lemansz20's Avatar
lemansz20
it will not fit, hres are designed to fit each car they are made for. Trust me like the hub is so tight on their dont take the chance.
Old Dec 28, 2006 | 09:40 AM
NIzzanturboka
wea i no but the hres i have where made for a g35 2 door and i put them on a s2000 lol....240sx....mustang....and a 300zx.... and my car soo i think they will bolt on i just dont no if they will stick out so much that i cant row the fenders...u get me i dont want to buy a wide body kit i think its ugly
