When buying rims..
Old Jan 7, 2007 | 03:38 AM
iceagetlc's Avatar
iceagetlc
Default When buying rims..
I have a 2003 Performance trim, I was told the rear wheel is bigger. If I wanted to get rims without new tires, do I have to order them special, or seperate? I see the term staggered, but I don't know how specific it has to be.
I hear all sorts of sizes for what mine is, like 18.75 and such... How should I go about this?
Old Jan 7, 2007 | 04:51 AM
Beau's Avatar
Beau
The rear wheels are a little wider than the fronts, but they are the same diameter all around. Depending on what tire size is on there right now determines how wide you can go w/o having to get new tires also.
Old Jan 7, 2007 | 08:03 AM
MR_X's Avatar
MR_X
When the rear wheel is wider than the front is called staggered fitment.
Old Jan 7, 2007 | 10:53 AM
The term stagger can have several meanings:
a. Rear wheels are wider than front. Say:
Front - 8 inches
Rear - 9 inches
b. Rear wheel diameter is larger than front:
Front - 18 inches
Rear - 19 inches
Specifications for the OEM wheels can be found here: http://www.350zmotoring.com/modules....ex&name=Wheels.
Old Jan 7, 2007 | 12:19 PM
DaveZ06's Avatar
DaveZ06
you should get a reverse stag setup and clip a metal plate on the back of your Z to make those oldschool hotrod sparks!
Old Jan 7, 2007 | 12:28 PM
iceagetlc's Avatar
iceagetlc
So what size should I get.
Justin100
Nov 25, 2021 06:26 AM
Alexreyes
Sep 30, 2015 11:30 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
