Need help with tires
Old Jan 8, 2007 | 10:10 PM
Jyoder7's Avatar
Jyoder7
Default Need help with tires
I'm replacing my stock tires with 245's front and 265's rear. I searched and its unclear whether I should get 265/35/18 or 265/40/18 tires. Anyone know whats the best way to go?
Old Jan 9, 2007 | 01:12 PM
Use a tire calculator to select alternative sizes: http://www.dakota-truck.net/TIRECALC/tirecalc.html
Old Jan 9, 2007 | 02:13 PM
TKW#13's Avatar
TKW#13
The actual plus fitment is 245/40r18 front 275/40r18 rear. I have fitment options for tires and wheels at my finger tips. If you need to know widths and profile for tires or widths, offsets, etc for wheels I have it!
Old Jan 9, 2007 | 02:37 PM
Jyoder7's Avatar
Jyoder7
The problem is that the car already understeers alot stock. Having a 30mm differnence will make it worse.
Old Jan 9, 2007 | 03:00 PM
TKW#13's Avatar
TKW#13
If you are going to run a width of 265 you need to run a 40 series tire to keep the height difference. 265/35r18 is almost 1/2 inch shorter than 245/40r18. Especially if it has traction control. The difference in tire height will definitely mess with the abs sensors.
Old Jan 9, 2007 | 08:42 PM
Jyoder7's Avatar
Jyoder7
Does anyone know if 265mm tires will fit on one of the front 35th AE wheels? I think they are 8.5inches wide.
Old Jan 11, 2007 | 09:42 AM
TKW#13's Avatar
TKW#13
The 35th Aniv. has 18x8 front 18x8.5 rear. The fitment guide that I have shows that 245 is the widest recommended tire for the front with no rubbing problems. A 265 tire on 8 inch width wheel the tire will probably look to big for the wheel
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
