RIMS.. and tire sizes.
I think im about to order these rims for my car
AXIS Haros.
http://www.wheelnext.com/default.cfm...or=HYPERSILVER
19 x 8.5(Front) +19x10.5(Rear)
245/35/19(Front) + 275/30/19(Rear)
do those tire sizes underneath the rim sizes seem like a good match. What tire sizes do you guys recommend??
AXIS Haros.
Originally Posted by DaveZ06
19 x 9.5 or 8.5 19 x 10.5
245/35/19 all around
But what offset are you going to get? offset makes a big difference in looks
18x8.5
19x8.5
19x9.5
19x10.5
Bolt Patterns
5x100, 5x114
5x100, 5x114, 5x120
5x100, 5x114, 5x120
5x114
Here is the link
http://www.axiswheels.com/wheels/hiro/hiro.html
so 245/35/19 all the way around dave??
I also dont plan on lowering the car any time soon, so will these sizes scrape at all??? and also can i get some more feedback on the tire sizes? Check my link for the offsets.
Guest
Posts: n/a
My guess for an offset on those will be around a +24
Originally Posted by dave079
I also already told you what tire sizes you will need. The ideal sizes for those rims will be 245/35 front and a 275/35 rear on the size rims you have chosen. You will not have any problems with rubbing.
If you are going 8.5 front and 9.5 rear you will want ideally a 245/35/19 front and a 275/35/19 rear tire.
SIDE NOTE - On my last car I had 9 front 10 rear. and had 275 35 19and 295 35 19 for the rear. should i get these same sizes?
seeing that im going to get 10.5 in the rear instead of 9.5, do you think it will rub?
If you are going with a +22 or higher offset then you will not rub. 285/35/19s would be the better application for a more positive offset. 275s will stretch on a 10.5" wheel.
Guest
Posts: n/a
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
